Page 16 of 149 FirstFirst ... 614151617182666116 ... LastLast
Results 151 to 160 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #151
    Jun 2012
    Canberra
    Just wanted to say a BIG thank you to DkN, pleasure to deal with and I installed my new ANS-810 on the weekend trouble free. The GPS did not like it inside the garage, but it all worked out once I reversed it into the driveway. First time doing anything like that before, and between the threads and 'how-to guides' and DkN's instructions I got it all done and setup pretty quickly. Very professional, highly recommend his services again!
    Thanks!
  2. #152
    Apr 2012
    DkN - are these units compatible with Dynaudio amp and speakers (factory option) in a MK6 Golf?
    Thanks
  3. #153
    Jun 2011
    Yup, fully compatible with Dynaudio.
    Quick update, I am about to get my hands on new firmware, and I have been informed that organising music by ID3 artist etc will be available for iPod very soon (next FW release) since the data is obtainable via iPod itself (i.e. not much re-coding of the ANS software).
  4. #154
    Apr 2012
    Thanks for the prompt reply
  5. #155
    Aug 2012
    UK
    Ok, primo appears to be working great apart from it not retaining its settings after power down, forcing me to go through the wizard on each startup. I receive the message "the applicatuon failed to start last time,do you want to lose all settings and poi". Any ideas anybody?
  6. #156
    Delete sys.txt and save folder.
    Sent from my HTC One X using Tapatalk 2
  7. #157
    Jun 2011
    Quote Originally Posted by riggsy View Post
    If you got it from a local dealer you should really confront them because it's ridiculous you have to go through this much effort yourself to get it working. They practically delivered you a sat nav unit without working sat nav. None of my customers have issues like what you are describing...
    If you delete sys.txt and save folder and still run into the same issue, try pressing "no" when that window comes up, because pressing yes obviously will mean Primo wipes user settings itself.
  8. #158
    There is something wrong with the config, so deleting the save folder and sys.txt will obviously run the setup again next startup. But once thats done hopefully it will be with the correct settings. This is the accepted method for resolving issues as described. As I mentioned earlier, the current versions of iGo do not need a sys.txt at all to work they should auto configure. Anything added to this config file has the potential to cause issues if the settings are not understood fully.
    There are a million and one tweaks that can be done using settings in this file however if the application is not starting correctly this is where to start, as well as removing the cache which is in the save folder.
  9. #159
    Jun 2011
    Update on the unit, I now have the latest FW revision which has finalised the video playback menu and includes several general bug fixes. However, in about 2 weeks time a new revision will be released to allow browsing of iPod by artist / song name (rather than file name), as well as fix the bluetooth contacts list to sort alphabetically - therefore I will wait for this more major update before distributing new firmware.
    If all goes well, by the end of this month OBDII features unmatched in the current market will also be released
  10. #160
    Aug 2012
    UK
    Karmold,
    Thanks for advice, tried deleting save folder and also SYS.text, you are correct, everything started up OK and GPS and general navi functions all working without a hitch. Unfortunately as soon as the unit looses power, I get the same old error reappearing on startup, any other suggestions?
