Originally Posted by
kamold
There is something wrong with the config, so deleting the save folder and sys.txt will obviously run the setup again next startup. But once thats done hopefully it will be with the correct settings. This is the accepted method for resolving issues as described. As I mentioned earlier, the current versions of iGo do not need a sys.txt at all to work they should auto configure. Anything added to this config file has the potential to cause issues if the settings are not understood fully.
There are a million and one tweaks that can be done using settings in this file however if the application is not starting correctly this is where to start, as well as removing the cache which is in the save folder.
