Page 143 of 149 FirstFirst ... 4393133141142143144145 ... LastLast
Results 1,421 to 1,430 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #1421
    Sep 2008
    Melbourne, Australia
    First thing I would "guess" is a poor connection somewhere, either in the unit (soldered joint) or a connector internally.
    Second would be is the car battery "low"?
    If you run the car for a few minutes then turn it on is it ok?
    Prev 2008 R32 3 door DSG.
    Prev 2010 S3 Sportback Stronic.
    Now Lexus IS350 F Sport
  2. #1422
    Mar 2014
    United Kingdom
    Quote Originally Posted by bazzle View Post
    Running the car makes no difference and it's not voltage related.
    It only does it based on temperature, if it's 15C outside it works without an issue.
  3. #1423
    Sep 2008
    Thats why I suggested a solder joint or connector.
  4. #1424
    Mar 2014
    United Kingdom
    I'm guessing finding the bad joint is going to be near impossible too
  5. #1425
    I'm beginning to think this is too good to be true. Shortly after getting the unit I complained that the Bluetooth mic is no good and have been playing email tennis with AS since. They want me to have it repaired locally at my cost! They asked me to take it apart to check the wiring and replace the mic
    ive been in contact with Sandy and was trying to update to M140. It won't read 3 of the cards I tried. Now the gps sd card slot won't read my navi card. It's a cracking device but you are on your own a little. I can't believe you can recieve a faulty product and be out of pocket.
    Does the gps sd card slot support fat32? The card I had working was 2gb fat. I temporarily deleted that to copy the FW updates to test another card. Now it won't update from and card I try and I can't browse for gps path anymore. Looks like the reader is shot.
    ....gggrrrrr
  6. #1426
    Mar 2014
    United Kingdom
    Quote Originally Posted by Jon0881 View Post
    The slot does support a card formatted to FAT32 but to update the firmware you need a card formatted to FAT.
    Your doing well to get emails back from AS, they are ignoring me now they have my money.
  7. #1427
    Jun 2011
    Sydney NSW
    Just noticed a couple of odd things on my ANS-610.
    I have the latest firmware applied.
    First, I have had it switch off without me doing anything at all. It does not happen when running, but after I have stopped it and then restarted. I have to manually start the unit by pressing the on/off button. About the only difference being that I am in Bendigo and the temperature is a lot lower than in Sydney where I normally am.
    The second is that if I let a call go through to voicemail, the navigation sounds turn off and I have to re-select the voice to get audio navigation and alert messages. What happened this time was I had the ignition in the off position but the key in the switch so the ANS-610 was on. While I was checking tyre pressures at a service station I heard the phone ring in the car, but I decided not to answer and let it go through to voicemail. When I restarted, there were no navigation or other sounds at all. Even the radio had to be selected again.
  8. #1428
    Apr 2014
    Hey guys, I've got an ANS-510 running M136 (I think)... when I go into reverse, I get the image of the car, and I can hear the beeps as usual, but I never see the proximity displayed on the screen? Do I need to recode the car (with VCDS) to support this?
    PJ
  9. #1429
    Mar 2014
    United Kingdom
    Quote Originally Posted by pjjoh1 View Post
    PJ
    You shouldn't need to re-code the car but your car has to support the visual parking control.
    Did you have it on your oem head unit? As I think for it to work you need the correct parking sensor control module which was fitted to later cars.
  10. #1430
    Apr 2014
    Quote Originally Posted by Hollinshead View Post
    Thanks, that should explain it then.. My 2006 B6 probably doesn't support it.
    Cheers, PJ
