Page 118 of 149 FirstFirst ... 1868108116117118119120128 ... LastLast
Results 1,171 to 1,180 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #1171
    Feb 2007
    Brisvegas
    Hi,
    my ANS-420 is asking me to select a file path or something like that when I select the satnav function. I press ok and it takes me to Primo2 folder and I select that then it brings up a heap of subfolders. Wondering which one I should choose and then finally which file.
    Thanks very much!
  2. #1172
    Jun 2011
    Sydney NSW
    Quote Originally Posted by VWindahouse View Post
    Hi,
    It is not in the sub-folders. It is at the bottom of the root. You have to scroll to it. You will have some "fun".
    Basically, you need to scroll down to find the primo.exe file. There are no scroll bars. You have to use your finger to "drag" the list upwards. Unfortunately, until you get the hang of it, you will end up in other folders and have to try again. Try and pick where there is nothing (easier said than done) and then drag your finger (while pressing on the screen) up the screen. Usually one drag should be enough, but you might have to do it again. Then pick the primo.exe file and all should be OK.
  3. #1173
    Feb 2007
    Brisvegas
    Why is nothing ever straight forward with this unit lol
    Thanks mate, will do my best.
    Cheers!!
  4. #1174
    Aug 2007
    Quote Originally Posted by wai View Post
    Extreme RAGE!!!!!!
    This has to be in my top 5, of the most frustrating things I've ever had to do.
    CW MY12 5Dr manual GTI. ANS-810 head unit.
  5. #1175
    Jun 2011
    Sydney NSW
    Thankfully you only have to do it once...per update. You get quite adept at it after the first couple.
  6. #1176
    Feb 2007
    Brisvegas
    Quote Originally Posted by starionx View Post
    Extreme RAGE!!!!!!
    HAHA I got lucky I think, first go
    Thanks for the advice, worked perfectly!
    So next issue - since the last CPU update every time I put the car in reverse it automatically goes to a reverse camera screen and kills the tunes. Only issue is I don't have a bloody camera I've done all the previous updates and it's never done this before.
    So tried reloading the previous update to get rid of it and it won't accept it. Can't remember exactly what screen it is but it's the one that comes up twice in the update procedure only the second time the text is meant to be in Chinese and you just hit yes. Sorry for the vagueness.
    So can the camera function be turned off or should I just wait for the next update and see if that loads and fixes things?
    Cheers!
  7. #1177
    Jun 2011
    Sydney NSW
    I don't have a camera either, but I don't get the guide lines. I end up without even the Optical Parking System unless I manually switch it out of navigation. Then I can see which sensors are triggering. Not really an issue once U worked out what to do.
    Sorry I can't help with the camera issue.
  8. #1178
    Mar 2013
    Greece
    I had the same problem with my ANS 610 and Sandy gave me an MCU update and the problem was solved. I think he will be back tomorrow.
    You can try turn it off from the secret menu (didn't work for me)
  9. #1179
    Feb 2007
    Brisvegas
    Thanks very much rivol!! I'll give it a shot tonight. You guys seem pretty knowledgeable about these things so one more question - When I first got the unit right up to the last update when I went into display colour it flashed the word blue for a second before you got the choices red and green. But when I quickly hit it while it was still showing blue nothing happened - Moral is I WANT BLUE TO MATCH MY DASH
    Any thoughts or secret menus I can try??
  10. #1180
    Feb 2007
    Brisvegas
    Unfortunately no joy with the sneaky hidden menu for me either
