Hello Sandy, while waiting for the new units i have started to think that the ANS810 buttons being on top is not OEM style so am thinking more about the 510-610 units now. i assume all have the same HW and SW and the only difference is screen size, right?
Thanks
All the units within the same series have identical hardware across the different models.
The knobs need to be on top for the 8 inch model because it's more narrow at the bottom. It still looks perfectly stock when installed, but those more familiar with VW would obviously be able to tell that's not an OEM model. There are a few pictures of the 810 installed in dash from this thread if you scan through the first 10 pages or so.
Perform a full firmware flash and then so another GPS reset, if that does not work then something is wrong with either the antenna cable or the hardware.
Special complimentary pics as your reference:-
ANS 510 on Golf TSI MK6
ANS 810 on Golf GTI MK6
As the screen resolution is identical (800 x 640) for both models, would that mean the smaller screen will actually look nicer? Same number of lines over a smaller area being my logic but please correct me if I'm wrong.
you can calculate the PPI:
Display Dimensions Calculator
and yes it should look better.
