2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
The B version has a limitation on the firmware it will upgrade to, this will put limits on SD card size and probably other things, I'm not too sure off the top of my head. The other benefit of the C version is that the LED screen is available and it has the voice control option. I personally haven't used a non LED version, but I have heard that they can be hard to see in direct sunlight. I don't get that problem. For an extra couple of hundred dollars now you will be much happier long term. I got mine for under $1000 with one of the make an offer auctions, just be patient and look at what's on offer. also, make sure you get one with Australian maps, and you will need an antenna adapter to make the plugs fit.
| .:R32 | MY08 | Deep Blue Pearl | Sunroof | RNS510 | MDI | OPS |
