Results 1 to 10 of 14
Thread: Another thread about RNS-510 (Golf mk5 gt)
    Aug 2011
    vic
    Another thread about RNS-510 (Golf mk5 gt) (Question)
    Okay, i know there is a lot of talk about these, however i am finding it hard to find some straight forward answers.
    I have an 08 (originally sold in august) golf gt tdi.
    I would like to know, if i purchase an RNS-510 version C, Software: 2840, H52.
    And i also purchase a vw premium bluetooth kit.
    Will I:
    - be able to integrate the gps into my MFD display?
    - integrate my ipod into the screen? (i have the cable)
    - integrate bluetooth into the screen and possibly mfd?
    - and use the steering wheel buttons to control calls, ipod songs, etc.
    Thank you
    ps: quite sure this is what my dash looks like:
    Nov 2007
    Quote Originally Posted by vraptor View Post
    Will I:
    Thank you
    You may have an older CANBUS so to avoid any battery drain issues I'd go for a Version B unit and get software under 2600 that way there won't be any chance of it. If you're desperate to get the Version C with 2840 Firmware you may have to upgrade the CANBUS. Not a big deal or overly expensive but if you want true plug and play then go the safe path. If you're buying the unit off Ebay just tell the seller you need a version B and to downgrade the firmware to under 2600. They should be able to do this.
    Upon plugging in your probably wont be able to view the GPS on your MFD unit , you need to do a bit of VAGCOM work and tell the car that you have a GPS unit now, then it will come up. You can do this yourself if you have a VAGCOM and there's tutorials online or just wait for your next service at the dealers and ask them to do it - its a 5 minute job.
    Lots of bluetooth options for it but the easiest and cheapest by far is the Fiscon Basic Plus unit from Kufatec. Again completely plug and play and it will display on your MFD + display extra stuff too like boost pressure ect. The premium bluetooth kit is apparently better but it can be a pain to install and code to the radio. I've read about lots of issues. Again go with whats safe. Here's a link to the Fiscon unit.
    FISCON Bluetooth Handsfree - Basic-Plus - VW, Skoda [36496] - $568.95 : Kufatec USA, Inc., The #1 Supplier of OEM Volkswagen & Audi Retrofit Harnesses in the World
    Not sure about Ipod connection and controls - I know it can be done but I don't think its as simple as plugging a cable in - I think there's some kind of Ipod module you need and probably more vagcom work.
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
    Aug 2011
    vic
    Thanks Poyta for the information, is there any way I can find out my CANBUS version?
    Apart from that it sounds like it will have full integration, if anyone knows about the ipod connectivity that would be awesome.
    ps. my current headunit (stock vw) has ipod connectivity, can I use the module from this?
    Nov 2007
    Apparently only via VAGCOM
    Jan 2011
    If you have a full height MFD there is a very good chance you have the right version CANBUS. I have a June 07 built MY08 R32 and that didn't need an upgrade. For Bluetooth I would suggest the 729 b skoda unit. This is the equivalent to factory premium without the fiscon advertising all over it. I had the original iPod cable too, it behaves like a stacker and when I changed over to the RNS it was cutting all the mid and low end off the audio, plus you only ever see track 1 on the display and have no control. Buy an MDI retrofit kit with the extended cable while you're buying parts and do it all in one go. I just changed mine over and it's heaps better.
    If you have any other questions just ask, I've done most of these upgrades and Bluetooth is the only one I'm left to do. I have a 729b kit on order.
    Mat
    | .:R32 | MY08 | Deep Blue Pearl | Sunroof | RNS510 | MDI | OPS |
    Aug 2011
    vic
    Argh things are stacking up now
    canbus- $130
    MDI - $250
    rns-510 - $1k
    might have to leave blue tooth for now, but that is still a lot more than I wanted to pay
    Jan 2008
    canbus- $130
    MDI - $250
    rns-510 - $1k
    If you car was delivered in August 08 it was probably built in May/June 08 and will have a new CAN bus already installed.
    Jun 2011
    rns-510 - $1k
    You can get them for less than $800 if you look hard enough.
    MY09 118TSI - SOLD
    Aug 2011
    vic
    Quote Originally Posted by hentaiboy View Post
    + delivery? the one's on ebay stack up to $1k, the ones below that either make up in postage, or end up getting bid on to just over 1k :S
    Jun 2011
    VW Navigation system MFD3 RNS 510 MEDIA C LED STAR * | eBay
    Make an offer...
    MY09 118TSI - SOLD
