Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Another Noob Here Needs Help BT & Media cable not working !
    Also the media cable supplied with the car may ONLY be the charging cable. To get music you need a "proper" media cable which is about $80 from VW or $15 on Ebay Even with the good cable mine always said device not supported but just click it off and it worked.
    Was such a pain to get phone in the glovebox I never used it once the novelty wore off. All music on an SD card and phone connects on Bluetooth.
    Thanks i'll look into that .
    Quote Originally Posted by Umai Naa!! View Post
    BT audio is Bluetooth audio streaming, which is a bit different.
    Any reason why it wont stream audio ?
    If phone button mutes there is no Bluetooth
    So from what i've been reading will i be needing a 9w7 module plus bluetooth kit ?
    Pacific Paradise QLD
    Usually do pairing in the MFD or you do in a Passat. My phone button only mutes I think in the few times I have touched it.
    Excuse my lack of knowledge but how do you go about pairing through the MFD ?
    Quote Originally Posted by Mr Poker View Post
    Well a read of the manual will tell you.
    But you go to the phone page in the MFD and down to connect and turn on discover on your phone and hopefully it will connect M<Ay need a white full MFD Kamold will know
    Ok thanks i'll give it a try & hopefully it works !
