Where do you set the voltage input? Couldnt' see it in the RNS510 menus.
Go to the "Setup" button on the right side of the display and then select the "Media" option.
When in "Media" you will see an option for Aux input level. There will be 3 levels of input voltage, 0.3V, 0.7V and 1.5V. The higher the input voltage is set to, the higher the volume will have to be set to get the same volume as the radio/CD.
There is basically no point To it though, as every album is recorded at different gains.
Well, not really. They are all recorded at a similar level as they generally want to get the best dynamic range etc, but the fact of the matter is, when I had it set at 1.5volt input, it was way too quiet and every time I switched to another source, like the radio, the volume level would blow me out of the seat. Now that they input is set to 0.7volt input, going from one source to the other closely matches each volume level.
Yeah just have to chose an average setting but I'm constantly adjusting volume and u can't really avoid that.
In other words you'll only have to adjust it a bit not a lot.
btw. I've got the Rev B firmware on the RNS-510 so it displays as low/med/high, I don't see the voltages but sounded the best with it on low & I don't listen to radio much anyway.
About the speed dependent volume i haven't noticed that it does very much at all.
Edit: Dont really get the thread, sounds like you've fixed the problem anyway.
That was all I was hoping for.
My initial question was to find out what the actual output voltage was for the iPod. Of course, this is the maximum output voltage, but this should correspond as closely to the input as possible so as it can get the best out of the amplifier with regards to signal to noise ratio and dynamics, etc. If the amp has to be turned up too loud in order to get a reasonable volume level, then you bring noise into play, lesser sound quality and also may not get the loudness required.btw. I've got the Rev B firmware on the RNS-510 so it displays as low/med/high, I don't see the voltages but sounded the best with it on low & I don't listen to radio much anyway.
Hmm not sure then, whatever works is the go (non tech answer lol).
I've got after market amps, dont konw if that affects anything.
Anyway i thought ipods were 5v, as some head units wouldn't charge the iphone, but the MDI may do something to it anyway so all assumptions.
