With a sealed sub, the acoustic loading should prevent the sort of excursion that would draw enough current to overload the amp (unless it's a crappy one with a claimed rating that's far higher than actual).
Originally Posted by
AALocksmiths
Either get a bigger battery or use a capacitor for your sub.
Or maybe thicker power and earth cabling
Resident grumpy old fart
