I'm no expert but dont think it would matter if this is mounted upside down for these amps.. there aren't any openings/fans etc but wonder what difference it would make if you screwed it on 'up the right way'?
Looks like a neat easy job, unique idea too! Doubt you'd have a problem but you never know. you could always flip it around with an air gap, kind of suspended but may not be as secure.
"One art please!" --->http://benno.redbubble.com
That's why I said to leave an air gap or spacers.
I wouldn't mount it upside down due to the heat issue and the fact that someone might kick it in. Im not familiar with that amp but the heat depends on the power it will be running and the power it is capable to running. If there are heat issues than its not to hard to mount it differently or just bung on the A/C.
Summer is where heat might be a problem. My 1000rms mono on 1/3 gain over heated very quickly in summer untill i mounted it properly. Alot of friends had similar issues in summer. Although im sure you wont be running the amp at P plater levels.
If i was you i would cover the mounting board in a material that is similar to the material on the dash and posibly round off the edges a bit for a more pro finish, that would make it look prity factory.
MK1 GLS 3door
A4 B7 2.0T
Settle the f*** down mate.
Ive had alot of experiense with car audio and im just telling you want i know.
Mounting it upside down increases the components exposure to heat, full stop. I don't know whether that exposer is great enough to cause issues in your amp and im not debating that. Its just something to look out for.
As for someone kicking it in, i'd rather be safe than sorry.
I would be more concerned about the distance between the amp and the sub more than anything else but if you don't mind it then im not going to get technical.
I do think its a great idea and i really like it. It would be great to see the end result with the board wraped in vynal (not with staples haha) and rounded edges for the profecional looking finish
If you don't want opinions then don't post on a forum. Just because you think something is great doesnt mean everyone else will.
MK1 GLS 3door
A4 B7 2.0T
I'm sure it will be fine. Don't listen to the nerds, i was running a video card with no fan for ages. If anything over time you may have a problem, like after 10 years.. (don't quote me but that's a guess).
