Results 1 to 10 of 10
Thread: Aftermarket issues.
    Aug 2011
    Melbourne, Victoria
    From what you've described it sounds like the radio is losing +12v battery voltage.
    When you wired it up you need to give it constant +12v from the wiring loom and ACC signal for the ignition switch which triggers the head unit to resume previous state or wake-up. From experience I'd say this could very well be your issue.
    -Mythik.
    Pacific Paradise QLD
    Normally the red and yellow wires on a standard unit Swap them over and I bet it will work
    Dec 2006
    Kilsyth, VIC
    As has been said it does sound like your head unit isn't getting a constant 12V. Did you check the lines with a multimeter before install to be sure?
    Nov 2012
    Just for anyone that reads this post, it was the old red wire yellow wire mix up.
    Kinda obvious really
    Dec 2006
    Kilsyth, VIC
    Glad to hear you got it sorted though, those little things get annoying very quickly.
