Results 1 to 10 of 12
Thread: Aerial connection - either bodgy fix or adaptor lead
    Erskineville, NSW
    As part of my Audience to Bolero upgrade I discovered the aerial connections were slightly different. No big drama as you expect these minor hiccups along the way.
    This is the Audience connector
    This is the Bolero
    As you can see, they are closer together.
    Is there a bodgy method I can use or would a cable like this do the job?
    Dec 2009
    Kew, VIC
    If they're otherwise identical you might be able to split the connector (hacksaw job?) and wangle the two sections in separately — would ensure you don't lose any signal strength.
    Erskineville, NSW
    Yeah, that might work. Kind of spread them in a V.
    I think N0063N said I could strip the outer plastic off the female connectors as well. i'm thinking rather than remove the whole lot I could file a flat on the parts that are interfering with each other
    Adelaide hills, SA
    These adaptors could be had for less than that, search the ebay.
    Erskineville, NSW
    Around $13 ex-China HK? that's the cheapest i can find.
    Dumb question.
    I assume I need the 2 into 2 & still utilise the beige coloured connector? or do I get the 2 into one & not connect the beige connector?
    Erskineville, NSW
    just found a post at briskoda that explains all the connectors, diversity antenae, etc.
    Slowly getting my head around this - doubt I'll need an adaptor with a bit of judicious file work
    brisbane
    make sure there is nothing else in the antenna system that is also different mate other that just the connectors.
    i'm having issue with my rns-e at the moment and it involves swapping out my antenna amplifier.
    you might be ok but i suggest its worth checking before you go hacking anything up...
    Jun 2011
    Sydney NSW
    Don't try and split the connectors as they are quite different.
    There is the twin connector that has two separate connectors, and the dual connectors that has them on a single plug.
    The reason you cannot split them is that the locking peg is offset on the dual connector compared to the single one, so even if you can get them split correctly, the locking peg will be extremely thin on on and none on the other.
    You can get correct plugs.
    Adelaide hills, SA
    Quote Originally Posted by wai View Post
    ...and when you get, here is the tip. Don't use it as an adaptor. Take it apart and use only the plastic housing, it won't clutter the space behind the unit.
    Erskineville, NSW
    Didn't bother with an adaptor.
    Without going into the minor issues I was having, I just removed the outside plastic casing & plugged them in. They aren't locked in place & could vibrate out eventually. I'll cross that bridge when I come to it.
    They actually went the opposite to what I had read elsewhere.
