I utilized the debug menu of the MIB Toolbox to document the logs; however, there hasn't been any advancement on this issue I was having. The system is unfortunately not providing adequate information on why integrating the old TMC database with the updated maps results in crashes. I think the mismatch between the location reference IDs could be the reason.
The issue appears to occur during the system's attempt to resolve MonoLineIds. It stumbles upon an assertion check for the validity range and, unfortunately, fails.
Furthermore, the TMC and MAP database files are in an encrypted SQLite format, and no substantial tools are available to decipher them into a user-friendly format
MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
Genuine VCDS HEX-NET and VCP Pro
Thanks for reply, so finally I assume for Discover Media produced by Delphi the only way to fix the issue is to decrypt zlibbed TI.NDS and placing it back to SD card. Becuase all extracted to RAM values from NDS files are just active while using by unit, and if I need to use changed values then I need to fix the source .
