Results 1 to 2 of 2
Thread: Adding Bluetooth or AUX music to 2007 Golf with RCD 300 head unit, how?
    Apr 2019
    melbourne
    Hi All,
    I have spent several hours search the net including this forum and need some help.
    I have a 2007 Golf TDI 2.0 Comfortline with an RCD 300 head unit and would like to add a simple bluetooth interface to stream music only for my recently licensed daughter. The car currently has an old VW iPad adaptor which has the old 30 pin connector which pretends to be the CD changer.
    What easy to install options and not too expensive are there to be able to play music from an iPhone? I am quite handy so can DIY.
    Bluetooth would be ideal but could live with just a 3.5mm AUX input. I don't really want to spend $200+ on a VW bluetooth kit but if I have to go that option what kit would work?
    Can anyone recommend any particular products? There seem to be heaps of products on ebay but I don't want to blow up my rcd300 and want the sound to be ok.
    thanks in advance.
    regards
    Chris
    Dec 2006
    Kilsyth, VIC
    Is the RCD330+ an option:
    Replacing RNS 510 with RCD 330+
    It's going to cost more than the bluetooth module, but far better outcome if you ask me since you get a shiny new colour screen, bluetooth and CarPlay in an OEM package that is effectively plug and play. The only thing to check is that when upgrading radios in the MkV's there are known battery drain issues which may need the CAN gateway to be updated as well.
