9WZ Bluetooth Network issues.
Jumped in the car today (Touareg, RNS, 9WZ). Phone normally connects within a minute.
Spotted the connection prompts on the RNS and MFD. Cool.
Selected number to ring, unit went into "I'm calling this number for you" mode. Within 30 seconds, it disconnects the dialing attempt with a screen message "No Network".
hmmmm.
Switch BT off on the phone (phone disconnects from the RNS). Voila!!!! Full signal on the phone. OK. BT switched on.
Rinse and repeat. Same result.
Reset the RNS and the phone several times. Same result. As soon as phone connects to the 9WZ, there is no network. Hmmm...dodgy phone?
Get home...grab wifey's phone (same brand/model as my phone). Same results.
I'm suspecting 9WZ connections, but will check this weekend. Anyone struck this? Any thoughts?
No VCDS scans done yet because the unit actually connects to the phone, just can't find the network.
