dark5had0w
Could you clear your PM box please?
I have tried all permutations....cannot get the S4 phone to connect unless rSap is operating on the phone.
dark5had0w
essentially, it is the phone that decides if it connects in remote sim access profile (rsap) or hands-free profile (hfp) mode, not the BT module.
that's why the 9WZ can operate in either rsap or hfp mode, depending on the phone.
when u pair for the first time, and the phone has rsap capability, it will ask u if u want to give the bt module sim access. if u say yes, then the phone will pair in rsap mode.
if u say no, it will pair in hfp mode
"JRVRS" is the 9WZ BT module.
if you're phone has already been paired in rsap mode, and u want to turn it to use the regular hfp mode, go to your phone's bluetooth settings and untick the "Sim Access".
rsap mode will say "Premium", u have access to sms and better reception as it uses the external antenna.
hfp mode
MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
PM sent
Hey, I have same prob with my phone. No Network. I've tried both rsap and hfp . I got samsung note and this issue started about 6 months ago, it did once upon a time work absolutely perfectly and all of a sudden ... it didn't
FJ Steve
I've been suffering the same issue and I think it is the BT module, so in about a month if it still aint sorted i'll have to buy the 9W7 unless their is another or alternative solution.
you could have a look at the Kufatec Fiscon basic Plus unit.
