Hi, do you happen to know what the difference between your dash L variant of the kit and the earlier 7P6035730K variants that are being sold on ebay. I am considering a 9w7 retrofit in my Golf and wanting to know which variant to get and from where. Will have a crack at fitting it myself if it is not too difficult.
Hi, AFAIK they are the same, but the L one have a slightly recent manufacture date.
However, usually the differences are minimal, in terms of software update or a slightly different components here and there inside the BT unit.
What I did during my choice was to find a version that had the manufacture date more similar as possible to the version of the head unit (in my case a RCD 510), take a look at this topic where expert forum member tigger73 advice the thing with more details: https://<br /> http://www.vwwatercoo...ad.php?t=87333
The installation is easy, do a search on this forum, there are plenty of useful topic.
I've bought mine from carsystem for 199€ plus shipping.
Cheers.
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
OK thanks for the explanation. Not much difference it seems between K & L then so will probably go for the best price.
Will go hunting for some install threads.
Hey I don't claim to be a guru on BT units I just did a fair bit of research from available information when I was looking to retrofit a BT unit into my 2011 Tiguan and the features I really wanted was the phonebook in MFD/RCD510.
In the end I gave up trying to find if the unit was going to be compatible and just confirmed with the seller that it had the features I was after. IMHO there is not enough information available on the various BT units to know difinitively all the compatibility/features/issues of each of the models.
Usually the newer BT units will have improved compatibility with newer phones. I have heard of some of the older BT units having issues with connecting to newer phones - though haven't experienced it myself.
I've also heard newer BT units can have compatibility issues with older head units (again this is not my personal experience just what I have heard). So I upgraded both head unit and BT at around the same time to pretty much current model units with no issues - plus got the features I was after.
I do make calls while in the car so being able to search contacts through the head unit/steering wheel is very useful (don't use audio streaming so not that interested plus I have MDI which I mainly just use for charging my iphone (I know it's a major waste but it came with the car).
