Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 9w7 retrofitted but no phone menu in white full MFD, why?
    Jul 2010
    Quote Originally Posted by Toki View Post
    I've tried to hold down the phone button on the MFSW and no chime sound, do I have to hold the star button instead of the phone button? I've the 8 button MFSW and RCD 510, not RNS, maybe this is the culprit...
    Not a star button! It should be a microphone button on bottom left hand side of SW:
    9w7 retrofitted but no phone menu in white full MFD, why?-dsc0116yz-jpg
    MY11 Tiguan 147TSI (SOLD)
    Unfortunately I have the old 8 button MFSW, like the one posted below, and it doesn't have a mic button, only phone and star: do you know if it's possible to activate PTT even with this SW?
    Aug 2009
    Melbourne, Vic
    ...just retrofitted a VW Bluetooth KIT Module 7P6035730L.
    Hi, do you happen to know what the difference between your dash L variant of the kit and the earlier 7P6035730K variants that are being sold on ebay. I am considering a 9w7 retrofit in my Golf and wanting to know which variant to get and from where. Will have a crack at fitting it myself if it is not too difficult.
    Hi, AFAIK they are the same, but the L one have a slightly recent manufacture date.
    However, usually the differences are minimal, in terms of software update or a slightly different components here and there inside the BT unit.
    What I did during my choice was to find a version that had the manufacture date more similar as possible to the version of the head unit (in my case a RCD 510), take a look at this topic where expert forum member tigger73 advice the thing with more details: https://<br /> http://www.vwwatercoo...ad.php?t=87333
    The installation is easy, do a search on this forum, there are plenty of useful topic.
    I've bought mine from carsystem for 199€ plus shipping.
    Cheers.
    Mar 2013
    Brisbane QLD
    Quote Originally Posted by logger View Post
    The older versions used to have a few issues with the phone not auto connecting...but not many..other than that they appear the same to the user in the car...VDUB..
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Aug 2009
    Melbourne, Vic
    OK thanks for the explanation. Not much difference it seems between K & L then so will probably go for the best price.
    Will go hunting for some install threads.
    What I did during my choice was to find a version that had the manufacture date more similar as possible to the version of the head unit (in my case a RCD 510), take a look at this topic where expert forum member tigger73 advice the thing with more details: RCD 510 3C8 035 190 C or 3C8 035 195 F and 9w7 BT compatibility.
    Hey I don't claim to be a guru on BT units I just did a fair bit of research from available information when I was looking to retrofit a BT unit into my 2011 Tiguan and the features I really wanted was the phonebook in MFD/RCD510.
    In the end I gave up trying to find if the unit was going to be compatible and just confirmed with the seller that it had the features I was after. IMHO there is not enough information available on the various BT units to know difinitively all the compatibility/features/issues of each of the models.
    Usually the newer BT units will have improved compatibility with newer phones. I have heard of some of the older BT units having issues with connecting to newer phones - though haven't experienced it myself.
    I've also heard newer BT units can have compatibility issues with older head units (again this is not my personal experience just what I have heard). So I upgraded both head unit and BT at around the same time to pretty much current model units with no issues - plus got the features I was after.
    I do make calls while in the car so being able to search contacts through the head unit/steering wheel is very useful (don't use audio streaming so not that interested plus I have MDI which I mainly just use for charging my iphone (I know it's a major waste but it came with the car).
