Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: 9W7 and iPhone4S drops Bluetooth Connection
    Nov 2010
    I'm having trouble keeping my iPhone 4s and 9W7 connected. I've had no problems previously with an iPhone 4 or 3GS, both running IOS 5.
    I've looked at a few threads regarding the 9W7 plus a few regarding the iPhone 4s and have not found anything.
    My problem is that the phone drops its Bluetooth connection once hanging up from an incoming call. It can be reconnected by "resetting" the link by disabling and re-enabling Bluetooth (easiest way to do this is by entering and leaving flight mode on the phone).
    I've seen a few posts on other forums suggesting that disabling Siri helps plus others saying that it's an Apple issue that may be fixed in IOS 5.1. I tend to believe it's an Apple issue as it's only been a problem on the 4s.
    I'd be really keen to hear whether anyone's had similar problems or if anybody has had no problems at with a 4s using other Bluetooth units (say a late version of the 9w7, a 9WZ or something)?
    Thanks
    dibdib, dubdub
    White Tiguan 147TSi, MY11 7Spd DSG, Park Assist, MDI, Phone Integration
    White Polo GTI 5dr MY12.5
    Nov 2010
    Just did a little experiment in the car this morning.
    I disabled Siri.
    Called my wife, no problem.
    My wife called, no problem.
    Exited the car.
    Got back in the car.
    Called my wife, "call failed".
    My wife called, rung out.
    This is going to be hard
    Anyway just thought I should post before anyone thinks that disabling Siri might fix the problem...
    dibdib, dubdub
    Sep 2009
    seaforth, nsw
    yes, same issue, i hop in my car, and my phone rings in my pocket yet it isnt picking up on the bt. if i reset, as u say, then it works. really annoying
    ive just learnt to reset the phone
    2011 cw golf gti 3dr man-tint-rear cargo mat-weathershields-bluetooth-mdi-19" oz racing ultra leggera-mcgard lockbolts-boston acoustic pro60se-jl audio xd700/5-jl audio bass tube bb-w060p- titanium exhaust tips-eibach custom pro-kit-OPS-OSIR cf mirror covers and cf front lip-dieselgeek short shifter
    Nov 2010
    Thanks Walbjj! It's good to know I'm not the only one and I'm not going mad.
    I upgraded IOS to 5.1 when the release came out on Thursday hoping it might help. It hasn't.
    I'd be interested to hear from anyone who has an iPhone 4S who hasn't had problems. What kind of Bluetooth setup do you possibly have?
    Thanks.
    dibdib, dubdub
    IN2VWS Guest
    I have a iphone 4S, and it works fine.
    I have a MY11 T5 Transporter with the RNS510 and premium bluetooth.
    Sep 2009
    seaforth, nsw
    i have the 9w7, as mentioned, used to work fine, but now have to reset
    Oct 2010
    Just chiming in that I have the same "dropping out" problem on the RCD-510 and Golf R MY11 with 9W7. The iPhone connects, makes a few calls, then the phone will ring but no ringing through the car speaker system but says it is still connected. And if I try to make a call it says it fails.
    Only fix so far, is to answer call on the iPhone, then turn bluetooth off and on, then connect back to car, then all ok for a while again. Or just flick Airplane mode on and then off.
    Things tried so far :
    Upgraded iPhone to 5.1
    Deleted pairing and re-added on iPhone
    Deleted pairing and re-added on MFD
    Disabled Siri to see if that is causing any problems.
    I am experimenting now to see if it is because I hang the call up or if they do, as it happens after that.
    Any other tips would be appreciated, and I will post back if I find a fix. I have an appointment to get MDI firmware update next week, so hopefully that will fix it.
    Sep 2009
    seaforth, nsw
    ^^^ did it used to work previously without issue? and then with the updates it no longer works?
    i reckon it was at least 2 updates ago
    goddamn apple
    Aug 2011
    Melbourne, Victoria
    MY12 Golf GTI - RCD510 + 9w7 BT - Works fine - iPhone 4 (not 4S) - firmware 5.1
    I've simulated the behavior from others testing above, no issues or call failures.
    Anyone got a iPhone 4 they can test their vehicles with to isolate if it's the 4S BT having a sook?
    Oct 2010
    It has only happened since iOS 5.0, I would consider going back to iOS 4 but need iOS 5 for iCloud etc.
    Sounds like a problem with the iPhone 4S and iOS 5. also the 4S has Bluetooth 4.0 and the iPhone 4 has Bluetooth 2.1. So maybe its because if the new type of Bluetooth and the rcd510/9w7
    Either way I was hoping 5.1 would fix it but no love yet.
