Hey Kash,
I just installed mine a couple of weeks ago into a GTI with an RCD510. See my post here http://www.vwwatercooled.org.au/f78/...9zb-45679.html
Install takes about an hour. Which unit did you get (did it come with all the cables, the mic and the underseat foam)? What head unit do you have? RCD510 or RNS510? It should work out of the box without any coding depending on what car and head unit you have.
If you want advanced functions to work like Push to talk and steering wheel controls for MFD then you will need to see someone with a VAGCOM. I went to see Jack at RAMSPEED in Seven Hills, only took about 15 minutes for him to code it. TCCM motorsports in Artarmon could also do the coding.
I enjoy these kinds of modifications and my bar fridge is empty at the moment. Send me a PM if your interested and maybe we can hook up sometime over the easter break.
Cheers,
Jamie
