Results 1 to 4 of 4
Thread: 30pin to Lightning adapter
    Jan 2010
    Has anyone noticed the bad audio quality coming from the 30pin to lightning adapter?
    there's alot of crackles and distortion if you listen carefully.
    Does anyone know if it's because of the analog output?
    If I put the song on a USB and run through MDI USB, it's fine.
    May 2010
    I have a new iPod Nano with no issues other than a bigger interuption at the start of when it changes each music track (which is more likely software than cable).
    GTI | Carbon | Man | 5 door | Leather | 18" Detroit | Bluetooth | MDI | Bi-Xenon
    Aug 2011
    Melbourne, Victoria
    Check the AUX Input Level is set to Lowest setting. The MDI output is line-level.
    Jan 2010
    but that doesnt explain, when i use USB, MDI cable.
    it's perfectly fine.
