I have a new iPod Nano with no issues other than a bigger interuption at the start of when it changes each music track (which is more likely software than cable).
Has anyone noticed the bad audio quality coming from the 30pin to lightning adapter?
there's alot of crackles and distortion if you listen carefully.
Does anyone know if it's because of the analog output?
If I put the song on a USB and run through MDI USB, it's fine.
GTI | Carbon | Man | 5 door | Leather | 18" Detroit | Bluetooth | MDI | Bi-Xenon
Check the AUX Input Level is set to Lowest setting. The MDI output is line-level.
but that doesnt explain, when i use USB, MDI cable.
it's perfectly fine.
