Originally Posted by
pandas
Finally got around to installing the front cam. A infant and a toddler just doesn't mix well with personal time.
Hillbilly, I noticed from another thread you used some sort of a clip to install the rear dash cam. Where did u get that clip / mount as it appears to be an easy way around mounting the rear.
Also ended up purchasing a genuine blackvue 64gb. Didn't want to play around with other brands as the 650 appears to be quite picky.
I made it out of a piece of Colourbond flashing I had lying around just folded it into shape and slid it in over the trim at the rear of the roof lining It needed the kink in it to make it grip better. Then used twinlock tape to hold the camera on. If it was a sedan I would have just put it on the rear window.
Was easier to do what I did than try and get the cable through onto the taildoor.
Did that on my Landcruiser and needed some personal lubricant to get the cable end through the rubber connector to the door
