![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
pandas
Will be going into a R36 passat B6, would the 2011 be a B6 or B7? The fuse layout should be pretty similar I suspect.
Yeah bought it with a power magic pro, I have a mini 0806 which is currently tapped into a mini blade, am I correct to say the non mini would be your constant live?
Quite possibly if the other one is always on I used spare sockets and metered them out to find which ones to use Found the ACC one by checking and then leaving for 30 mins and check again as some have quite a delay before they turn off completely. Have removed the PM as dont really need parking mode so have both cameras running off the same fuse now
