![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
pandas
Ended biting the bullet and purchase a DR650S-2CH.
Any recommendations on which constant live fuse to tap it into, or does it not really matter?
Only connect it to a constant supply if you are also using a Power Magic otherwise you will run the battery flat possibly overnight.
Best to connect to an AUx fuse if you have only the cameras
As you dont say what car you have I have included some pics of my Passat wiring. Unfortunately I cant remember which is always on and which is Aux and also different models may use different fuses. Mine is a Highline with everything 2nd pic shows the cable to the front camera going up into the gap between A pillar and dash.
I used different fuses in spare slots Not Addasfuses but I dont hink Jaycar sell these any more
