Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: 2 Channel Dash Cam with Parking Mode - Thinkware, Blackview or iRoad
  1. #21
    Pacific Paradise QLD
    Quote Originally Posted by pandas View Post
    What sized microSD card are you using ? Do you get much footage out of it and are you using a genuine Blackvue or 3rd party? Considering getting a 64gb, a Lexar high endurance will cost $50 whereas a genuine blackvue would be $20 more.
    Despite what has been said about them I am using Sandisk & Samsung 128GB cards Bought them on Amazon for about $59 each
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Sandisk is a 128Gb UHS-/1Class 10 ONLY BUY OFF AMAZON proper NOT AMAZON SELLERS
    If you format them correctly they will work in older models as well Like the DR400 in my wifes car.
    Blackvue are like Aldi they dont make the stuff so get rebranded ones off some factory
  2. #22
    Apr 2013
    Sydney NSW
    Finally got around to installing the front cam. A infant and a toddler just doesn't mix well with personal time.
    Hillbilly, I noticed from another thread you used some sort of a clip to install the rear dash cam. Where did u get that clip / mount as it appears to be an easy way around mounting the rear.
    Also ended up purchasing a genuine blackvue 64gb. Didn't want to play around with other brands as the 650 appears to be quite picky.
  3. #23
    I made it out of a piece of Colourbond flashing I had lying around just folded it into shape and slid it in over the trim at the rear of the roof lining It needed the kink in it to make it grip better. Then used twinlock tape to hold the camera on. If it was a sedan I would have just put it on the rear window.
    Was easier to do what I did than try and get the cable through onto the taildoor.
    Did that on my Landcruiser and needed some personal lubricant to get the cable end through the rubber connector to the door
