Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 62
Thread: What oil are VW dealers putting in your TDI engine?
  1. #31
    Pacific Paradise QLD
    Quote Originally Posted by kaanage View Post
    The receipt from the recent service of our TDi says 5W/40, just like it did last year
    Hope they didnt use it or maybe the muppet that did the receipt couldnt find the correct one in the computer.
    The price would give an indication 5w 40 is about $15 less than the correct oil which cost me $83 for 5 L off a stealer According to the list all 504-507 is 5W 30 Also it is the correct oil for a engine with a DPF
  2. #32
    Oct 2010
    Melbourne, VIC
    I went and queried them last year after seeing the receipt (I didn't pick up the car either time) and they told me they hadn't updated their computer to the 'new' oil spec. see my posts in this thread - Dealer used Havoline 5W-40 12month service, 2.0 TSI. It's actually 3 years running they've done this.
    The recent receipt says Helix Ultra 5W-40 for $61.04 (exGST) but no quantity is listed - looks like I need to pursue it with them again
    Resident grumpy old fart
  3. #33
    Jan 2009
    Quote Originally Posted by njg02 View Post
    Says on the print in the boot that it is suitable and the service guy was keen, as I was, but no go.
    Bah! VW are such spoilsports for locking the option!
    Pity, as I certainly think it would have made for an interesting experiment.
    PD TDI or CR TDI engines without DPF require 505.01 (fixed service intervals) or 506.01 (variable service intervals). 507.00 is also acceptable (irrespective of service regime), though not compulsory.
    Any TDI engine with a DPF requires 507.00
    The oil's viscosity grade isn't that crucial - it's the oil standard that needs to be paid attention to.
    Shell Helix Ultra 5W-40 has 502.00/505.00 approval - therefore, it is not suitable for any PD TDI or CR TDI engine.
    505.00 can only be used for TDI engines without PD (Pumpe Düse, or unit-injection in English) or CR (common-rail).
    It's actually 3 years running they've done this... looks like I need to pursue it with them again
    Unless you have reasons not to, I would strongly consider taking your elsewhere for future services.
  4. #34
    Shell Helix Ultra EXTRA 5W 30 is the correct oil for a DPF engine NOT Helix Ultra which is a 502-505 for NON DPF engines
  5. #35
    Jan 2009
    It's not quite as simple as that.
    PD TDI and CR TDI engines without a DPF require 505.01 or 506.01
    505.00 is not acceptable for these engines.
    Note that 507.00 can be used where 505.00, 505.01 or 506.01 is specified (with some exceptions).
  6. #36
    Quote Originally Posted by Diesel_vert View Post
    Most wouldnt know these engines as they are only in Touaregs and in certain years arent they.
    Perhaps we should state the models that each come in for those who dont know
    I am trying not to over complicate things as most are referring to Golfs Polos or Passats or the Skoda variants as there are hardly any Touareg owners on here with minor exceptions.
  7. #37
    Adelaide hills, SA
    To make it simple stick with the 504.00/507.00 in everything made after 2000 where only exemption is V10 TDI Touareg and R5 TDI as found in the Touareg and T5 up to 6/2006, because after 6/2006 they had DPF fited and again must use 507.00
  8. #38
    Jan 2009
    The Polo 9N (2005-2009), Golf Mk5 (2004-2009), Jetta (2006-2009) and Passat B4 (2006-2009/10) ranges were fitted with PD TDI engines, of which the vast majority were not fitted with with a DPF. Same deal with Skoda.
    From 2008/2009 onwards saw the gradual changeover to CR TDI engines, of which the vast majority of were fitted with a DPF.
    I think 504.00/507.00 is not strictly necessary in any engine that doesn't have direct-injection.
    EDIT: It's VW's fault for making it so bloody stupid and complicated - don't blame me, I'm just the messenger!
  9. #39
    We could argue forever about this but Transporters post simplifies it so that most would understand.
    Basically it doesnt hurt to use the 504-507 oil in any TDI engine except those he mentions.
    This makes it nice and simple without going into years and models (which change midyear as well)
    Far better to use a top spec Approved oil than think what you maybe can use and do it wrong.
  10. #40
    Jan 2009
    You said that 505.00 is for engines without a DPF, but that is not strictly correct.
    PD TDI and CR TDI engines without a DPF should be using 505.01 or 506.01 or 507.00
    And then you said PD TDI engines are mostly relevant for Touareg owners, but that is also not strictly correct.
    Many Polo, Golf, Jetta, Passat and Skoda owners (as well as many other models) would be very familiar with the PD TDI engine, most of which were not fitted with a DPF.
    These owners should not be using 505.00 in their cars just because they're not fitted with a DPF.
