Penrite (Enviro Plus) & Nulon (Full Synthetic 5W-30 EURO Engine Oil) Oils are available at our local Auto Pro. Both are 504.00/507.00.
Maris
Penrite Enviro Plus 5W-30 available from most good autoparts stores.
Supercheap Auto has Shell Helix Ultra Extra 5W30 5L for $69.87 from 29.9.10 till 16.10.10
Sent from my HTC Desire using Tapatalk
Maris
I'm not sure that the Nulon is approved oil? It says formulated to exceed the demands of VW504.00/507.00, which doesn't mean that the oil was approved by VW.
I wouldn't use it you will void your warranty.
If a person was to use Nulon Oil in their VW and there was an engine problem, then it would have to be proved that the oil was the cause of the problem. If that was the case, then a claim against the oil manufacturer would be in order.
While the Penrite Oil web site states "Approved oil for Volkswagen/Audi diesel engines and direct injection petrol engines calling for Longlife III Type (VW 504.00/507.00 approved) engine oils.
SAE 5W-30, VW 504.00/507.00 MB - Approval 229.51 and BMW LL-04", it does not say that Volkswagen approved it. In fact it give the approval numbers from Mercedes & BMW, so in our case, it is no better than Nulon.
Maris
I just found this on the Penrite site in a different paragraph;
"Enviro Plus 5W-30 carries full Volkswagen approval."
Maris
- Ben
1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
2008 Jetta 2.0L FSI
Somebody met with Peter Sandford.
It's good to see that Penrite is serious about the oils.
Just picked up 5 litres of Castrol SLX Powerflow III from my local VW parts department for $78. I thought people said that you couldnt buy this oil anywhere? And got some oil filters through a contact at Audi. Keen to change the oil now.
