Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: VW 505 01 Engine Oil
    Jul 2006
    South Australia
    The following Engine Oils meet the VW 505 01 Specification:
    Mobil Synt S Special V 5W-40
    Mobil Synt S Special V 5W-40 is a high performance diesel engine oil using a synthetic based formulation. It is primarily intended for use in Volkswagen pump-jerk diesel engines where an oil approved by Volkswagen to their specification VW 505 01 is required. These engines are filled on production with an oil of this quality.
    This is the only oil I have found so far to meet this spec in Australia. I will continue my research.
    Australian VW Caddy Forum
    http://www.getphpbb.com/phpbb/index....um=dutchaussie
    Australian VW Caddy Website
    http://VW-Caddy.yolasite.com
    Jul 2005
    Have you looked at the Fuchs range of synthetics for TDI's and FSI's ?
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Jul 2006
    South Australia
    Quote Originally Posted by aprr32 View Post
    I have read the name before but have never seen any of their oils in Australian shops.
    I will do some more research.
    I am looking for oils meeting the VW 507.00 spec for our 2007 VW Caddy.
    Mar 2007
    Hitlon WA
    Quote Originally Posted by DutchAussie View Post
    you are not going to find any. It is specially made by Castrol for VW and it is not available for retail.
    I have tried
    GOLF V 2.0 TDI COMFORTLINE
    SAY NO TO INTERNET FILTER http://www.getup.org.au/ http://nocleanfeed.com/
    syncro Guest
    It's a specification not a brand.
    Quote Originally Posted by acdcfan View Post
    I have tried
    This true as I've been through the same scenario with my bro's GTI.
    Apparentely VW has a deal with Shell oil now as that's what I've been told by my friend at VW.
    Obviously Shell made a better offer. This happened to BMW awhile ago when they converted to Castrol from Mobil & all the product's had to be replaced.
    I your after info on what oil to use, check here in the lube section. These are all for the Mk5 GTI
    Castrol
    http://www.datateck.com.au/lube/castr_au/
    CASTROL EDGE SPORT 5W-30
    Castrol Edge Sport 5W-30 is a full synthetic SAE 5W-30, API SM/CF. ACEA A3/B3/B4 engine oil formulated for highly tuned fast fours and latest technology engines. It provides superb strength and ultimate protection even when running hard, fast or hot.
    Service Refill Capacity: 4.6* Litres (See Note 56
    Shell
    http://www.shell.com/home/page/au-en...lubematch.html
    SHELL HELIX ULTRA 5W-40
    Mobil
    http://www.datateck.com.au/lube/mobil_au/
    MOBIL 1 0W-40 or MOBIL SYNTH S 10W-40 or MOBIL SUPER S PLUS 10W-40 or MOBIL 1 0W-40
    Hope his clears up a few thing's & help's out.
    Mar 2007
    Hitlon WA
    Quote Originally Posted by syncro View Post
    Yes, but for diesel engines there aren't any oils with same specs that you can find in retail shops.
    You can buy it from a dealer for around $25.00/L. but for topping up purposes you can use fully synthetic 5W-30 or 0W-30
    Adelaide hills, SA
    Buy it in 5 L, it is cheaper.
    Mar 2007
    Hitlon WA
    Smile
    Quote Originally Posted by MRL T5 View Post
    I haven't tried to buy any yet I just know this 'cos dealer offered it to me when i was picking up my car
    Jul 2006
    South Australia
    Yes, I recently found this brand.
