Results 11 to 20 of 26
Thread: VW 505 01 Engine Oil
    Jul 2006
    South Australia
    VW 507 00 Oil
    Quote Originally Posted by acdcfan View Post
    Yes, but for diesel engines there aren't any oils with same specs that you can find in retail shops.
    You can buy it from a dealer for around $25.00/L. but for topping up purposes you can use fully synthetic 5W-30 or 0W-30
    Have a look at my Website & Forum for information.
    Australian VW Caddy Forum
    http://www.getphpbb.com/phpbb/index....um=dutchaussie
    Australian VW Caddy Website
    http://VW-Caddy.yolasite.com
    Feb 2009
    Kingsgrove, NSW
    Nulon 5W-40W is 505 compatiable... a bit pricey but so far so good on a 1.9 TDI
    Adelaide hills, SA
    Quote Originally Posted by jacob_1987 View Post
    It must be VW approved not a compatiable. It is not the same.
    Shell Helix ultar extra from Repco is on special $79.95
    Stick with oils from the oil companies it is safer.
    Feb 2009
    Kingsgrove, NSW
    sorry it is approved www.nulon.com.au
    Feb 2009
    Kingsgrove, NSW
    Meets or exceeds the high performance specifications of the following vehicle manufacturers:
    BMW long drain LL-98, LL04
    Mercedes Benz 229.51
    VW 50200, 50500, 50501
    Porsche Approved
    Adelaide hills, SA
    Well their product is not good enough for many VW TDI applications, so I rather use the highest quality oil especially if there is not much difference in the price. Be every careful what oils do you use, since money you save now, doesn’t have to be enough for paying the repairs later.
    Directly from Nulon website lube guide:
    See limitations at the end of the guide.
    Recomended lubes for:
    GT Sport 2.0L TDI:
    If fitted with DPF refer to dealer,,,,? GOLF GT SPORT 2.0L TDI has DPF
    GOLF 2.0L TDI Not for vehicle with DPF
    They are showing Nulon 5W30 long life which is not for long life regime and what is more important it doesn’t say VW Approved.
    http://www.datateck.com.au/lube/NulonAus/default.asp
    Basically their 5W40 Diesel and Petrol oil was approved for VW505.00 and VW505.01 only and not 5W30. Only this oil say "Approved by VW".
    I didn’t find any Nulon oil with VW504.00 VW507.00
    http://www.nulon.com.au/products.php...rol_Engine_Oil
    Jan 2009
    Quilpie, Qld
    http://www.tds.castrol.com.au/pdf/50...90_2007_03.pdf
    This is what VW uses for their 507.00 specification oil in the dealer workshops.
    Adelaide hills, SA
    Lightbulb
    Quote Originally Posted by mulga1 View Post
    VW dealer in Adelaide is selling only the imported oil in VW labeled containers and it doesn't mention what oil company is making oil for them. I'm getting suspicious that it could be for the reason that oils from Castrol and other oil companies in OZ were not good enough and VW HQ decided to take full control and supply the oil to the dealers.
    Jun 2006
    Orange NSW
    Errr.. More likely if they label it VW and do not share where the product came from, they can charge more for it and gain a higher profit margin.
    Castrol makes some of the best oils in the world. VW recommends Castrol.
    Adelaide hills, SA
    Well actually the label says "Made in Germany".
    In Europe VW supply oil to dealers unlike here - they can buy whatever.
    Oils made in OZ are not as good as EU oils. IMO. Anybody is welcome to disagree.
