Short answer : "Use VW 504.00 spec oil"
Longer answer : "If you do a search you will find more info about engine oils than what you will know what to do with"
am a bit confused, So which oil is for my Golf V GTI? is VW 502 or 504?
Which one is better?
I was using Mobil 1 with my previous car. is Mobil 1 suited VW? Are they a good oil for VW?
Thanks for your reply.
Use Mobil 1 ESP, it is the latest oil from Mobil for VW and you should be able to get it from Mobil oil distributor. In Adelaide it is ROTO OIL ( 08 ) 83598997
I buy it in 20L drums not sure if it's available in 5L containers.
Shell Helix Ultra Extra is at Repco for $79.95 5L
It is VW504.00 VW507.00
Using 504 00 spec oil on my 2005 golf 2.0FSI. apparently this is supposed to allow "longer service intervals"- is this the only reason why I would use this spec? IF I change my oils at 5k or even 10k instead of the 15k/12months, would I be wasting money on this expensive oil? should I get something cheaper that is at least 502 00 spec instead? and does anybody know if its better to use brand x over brand y, or is all marketing hype and the perceived performance gains/smoothness of the engines all in our heads?
Try Royal Purple as a oil. read many good things about it.
ELF Solaris 5W30 is well priced and has VW 505.01 specs or Penrite HPR Enviro + 5W30 has VW504.00 specs and is around $65.00 for 5L
I would always use the highest quality oil I can get.
From your post I see that you're ready to change oil at 5,000km, so obviously you plan on keeping that car for long, long time, so why just for the sake $20 or more use cheap oil. Higher specs oil will protect your engine better. As long as it is approved for your engine.
My pick was MOTUL Specific 504.00/507.00 5w30
09 VW GTI Pirelli / DSG / 5 door / Black magic / Bluefin / TAI / Kenwood DNX7340BT / R.C /
09 Suzuki B-King /1340 cc / 181 HP /
