Results 1 to 10 of 10
Thread: Vw 502 504 507
    Vw 502 504 507
    am a bit confused, So which oil is for my Golf V GTI? is VW 502 or 504?
    Which one is better?
    I was using Mobil 1 with my previous car. is Mobil 1 suited VW? Are they a good oil for VW?
    Thanks for your reply.
    Canberra
    Short answer : "Use VW 504.00 spec oil"
    Longer answer : "If you do a search you will find more info about engine oils than what you will know what to do with"
    Adelaide hills, SA
    Use Mobil 1 ESP, it is the latest oil from Mobil for VW and you should be able to get it from Mobil oil distributor. In Adelaide it is ROTO OIL ( 08 ) 83598997
    I buy it in 20L drums not sure if it's available in 5L containers.
    Adelaide hills, SA
    Shell Helix Ultra Extra is at Repco for $79.95 5L
    It is VW504.00 VW507.00
    Mar 2009
    sydney
    Using 504 00 spec oil on my 2005 golf 2.0FSI. apparently this is supposed to allow "longer service intervals"- is this the only reason why I would use this spec? IF I change my oils at 5k or even 10k instead of the 15k/12months, would I be wasting money on this expensive oil? should I get something cheaper that is at least 502 00 spec instead? and does anybody know if its better to use brand x over brand y, or is all marketing hype and the perceived performance gains/smoothness of the engines all in our heads?
    Dec 2008
    Carina, QLD
    Try Royal Purple as a oil. read many good things about it.
    Adelaide hills, SA
    Quote Originally Posted by hienous View Post
    ELF Solaris 5W30 is well priced and has VW 505.01 specs or Penrite HPR Enviro + 5W30 has VW504.00 specs and is around $65.00 for 5L
    I would always use the highest quality oil I can get.
    From your post I see that you're ready to change oil at 5,000km, so obviously you plan on keeping that car for long, long time, so why just for the sake $20 or more use cheap oil. Higher specs oil will protect your engine better. As long as it is approved for your engine.
    My pick was MOTUL Specific 504.00/507.00 5w30
    09 VW GTI Pirelli / DSG / 5 door / Black magic / Bluefin / TAI / Kenwood DNX7340BT / R.C /
    09 Suzuki B-King /1340 cc / 181 HP /
    May 2009
    Quote Originally Posted by blackb6 View Post
    Yeah They are apparently good! I have em in my new R32. Very smooth
    Quote Originally Posted by blackmagic View Post
    where can you get this in Syd?
