Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: VR6 Engine oil recommendations?
    Jan 2009
    Quote Originally Posted by Weeds View Post
    Hello,
    Have a 96 VR6 with approx 280 000kms on it, not sure the exact recent service history, although know the previous owner who was pretty good with his servicing / care of the vehicle etc.
    Just curious what type of oil / viscosity to use, dont mind spending up to around $80 for a good bottle of oil?
    Hopefully, the engine is in a good enough condition not to warrant the use of extra thick oils.
    Any oil that meets "ACEA A3/B4" is suitable - preferably xxW-40 if the engine is in good condition, or alternatively xxW-50 if oil consumption is excessive.
    Feb 2007
    Perth, WA
    I have run:
    Fuchs Titan Super GTO 10w-40
    Penrite SIN 15w-40
    Motul Turbolight 10w-40
    Castrol Magnatec 10w-40
    All were fine, although the engine burnt fuchs at a much higher rate then the others.
    SIN was amazing stuff but total overkill.
    Motul was very nice but honestly these engines arent hard pressed or in a high state of tune, so i've been running Magnatec for a year or so without problems.
    ps. this topic has been covered a million times in the mk3 forum. Do a search!
    Jan 2009
    Too bad one can't search for terms with less than four characters, such as "oil" (boo!).
    Apr 2011
    Quote Originally Posted by MattyT View Post
    I have run:
    Penrite SIN 15w-40
    Aren't forums for people too lazy to search the internet :p
    but yes doing a search on oil brings up everything and considering the kms on the engine, thought I would ask...
    96 VW VR6 Golf (Daily driver)
    65 VW Beetle (Under restoration)
    Apr 2011
    Sorry one more quick related question, having never owned a Euro car before, are your standard Ryco type oil filter ok or do you need to buy manufacturers?
    May 2010
    NQ
    I may get blasted for saying this, but Ryco filters will do the job (Dont kill me)
    People (on this forum) have seen them blow crack/bust the seal, but I truly don't beleive it to be very common.
    If you can, try and use OEM Mann/Mahle filters (your in a big city so you may have better luck sourcing them)
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
    Adelaide hills, SA
    Quote Originally Posted by ryana89 View Post
    However, the Ryco filters are more expensive than the OEM filters.
    If you can't get OEM filters where you live then I suppose you don't have many options, but you can still order on line and get them delivered.
    Feb 2008
    mOOROOLBARK
    Apr 2011
    Quote Originally Posted by mk3pete View Post
    Awesome, thank you, DID search here but couldn't find anything, cheers.
    Black beauty just clicked over 200k the other day so thought I'd better check oil, only to find it just touching the dip stick. Have been racking my brains thinking what oil to use but seems like Castrol Magnatec 10w40 is ideal
    It's my daily and I'm a advocate oil changer every 5000 (typical for rotaries which in use to)
    So lest I won't be forking out to much money every time
