Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: VR6 engine oil?
    Jan 2007
    sydney
    They are at 20 joyce st pendle hill 96882933, stock air & watercooled parts
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by 95vr6 View Post
    added to my address book, will HAVE to give them a closer look, specially if they have that filter at HALF the price McGrath charge. Nice.
    Nov 2007
    brisbane
    yer volksbahn are good have delt witrh them in the aircooled side of VW's and have never had a trouble with them!
    i might chase him up and get him to post one up here!
    cheers
    rhys
    Feb 2007
    Bunyip, Victoria
    during the summer months i use a 20w 50, as in australia, the tempriture is much higher than in germany where they decided on what oil to use.
    I did compition motocross for a while, and getting the wieght of the oil right for the conditions made a huge differance to the life of the motors.
    The hotter it was, the heaver oil we used. The bikes where air cooled, so tempriture was important.
    Feb 2007
    Perth, WA
    Surely VW would not be as short sighted as to recommend an oil used based soley on the ambient temperature in the fatherland??
    Nonetheless, I want to put in 10w-50 come my next change for the stinking perth summer and the track work on the horizon
    Jan 2007
    sydney
    Quote Originally Posted by ScienceVR6 View Post
    Two different engines, air cooled need heavier oil, i use castrol 20w 50 in my oval, but way to heavy for a VR6 motor. 10w40/ 15w40 is recommended.
    Feb 2007
    Bunyip, Victoria
    If you look at oils solely on the viscositys in regards to tempriture, a 10w 40 or a 15w 40 arn't nearly heavy enough, they turn to water in the heat. i basically don't trust them to look after my motor on a 35 degree day when the engine oil temp is 115 degrees
    Feb 2007
    Perth, WA
    So by that token, 10w-30 in the summer, 15w-40 in winter???
    Aug 2006
    Skye, Victoria
    I think the other way around.
    Feb 2007
    Bunyip, Victoria
    Quote Originally Posted by BlackVr6ix View Post
    yeah, in summer you need a thicker oil couse it thins out in the heat.
