Originally Posted by
ryballs
Our recently purchased 2010 Passat with 2.0T is using oil at a fast rate, approx 1L per 2000km. Even though VW says that is apparently normal in the owners manual, I would like to decrease this if possible.
I tried topping up with 504 approved Penrite 5w30 fully synth, but it was used very quickly and is expensive. So this time I bought some 502 approved Shell HX7 10w-40. Now I know everyone goes on about how you gotta use the 504 but I specifically chose the 10w-40 as it appears to be the thickest 502 approved oil I can easily obtain. My hope is because of this it won't evaporate as quickly. Also it's very cheap compared to the fully synth so won't cost me an arm and a leg.
The oil says 502.00 / 505.00 on the bottle whereas the manual asks for 502.00 / 505.01. I guess I just want to know, will using this oil void my extended warranty or potentially damage my engine?
Is it a PETROL or a DIESEL
If its a diesel it should use 504/507 APPROVED oil such as the Penrite you were using.
Nothing might happen using the other but if it does and VW do an oil test you could be up the creek looking for a big paddle.
Its to do with the ash and sulphur?? content and using different spec oil could ruin the DPF which wont matter much except they are about $4000 to replace.
