Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Track oil temps on daily driven car
    Erskineville, NSW
    As I said previously, I'd experiment with oil types a bit.
    I would also look at what level of cooling / heat release you are getting. Start at the front around the radiator / IC area & plug up any (even bolt holes) airgaps with foam rubber strip. You want it so the air comes in through the grille & has nowhere else to go except for through the radiator. This will force the maximum amount of air through the radiator.
    I don't hink it's necessary to remove the lower grille but it's something to think about.
    If your model has the underbonnet insulator, I'd remove it for track days (it's like 5 minutes work).
    On track days, remove the rubber strip (2 minutes) that seperates the engine bay from the plenum - don't worry about adding something to dress it up.
    As a more permanent mod, you can put some spacers/washers between the bonnet & the bonnet hinges to lift the bonnet at the back - we used to do this on Toranas back in the day . My Torana 1200 had everyone fooled with that mod.
    Here's one to add to the world of bizarreness category. A guy over at OCAU once used heat sink epoxy to glue CPU heatsinks all over his sump pan. I wish I could find the photo as it looked like his engine was being molested by a mechanical porcupine. I have no idea of the efficacy of the mod.
    If you're really desperate - turn the heater on.
    Jan 2012
    Changing the oil is probably the cheapest and easiest option for the moment.
    Fortunately, water temps are perfect on the track, so additional air-flow wont assist the oil temp issue. Plus no matter how cool I get the radiator, the thermostat will always regulate the temperature.
    I think ill wait to see what the golf R sump looks like. Its using a TSI engine, and I believe they are modified for the extra power output, and can cater for the extra G forces on cornering. they may also use a larger oil heat exchanger. again, ill have to wait. but im in no rush
    thanks for your feedback guys!
    Erskineville, NSW
    Keep in mind that any gains you make in airflow through the radiator will also benefit the IC
    Jan 2012
    That's very true!
    And I have yet to fit my big IC too
    Erskineville, NSW
    Get the hoses sorted yet?
    Jan 2012
    nup. ill just buy the adaptor elsewhere. too hard dealing with the people who sold me the kit. for the price I paid and getting a $40 adaptor, im still better off than any big brand name kit.
    Quote Originally Posted by zei20t View Post
    Did you see the place selling the adapter that i linked to in your intercooler thread?
    Jan 2012
    yes I did thank you!
    haven't had much time and many CBF moments too haha
