Results 21 to 30 of 33
Thread: shell 100 octane
  1. #21
    Jul 2007
    Brissy
    Quote Originally Posted by VDUBXTC View Post
    Both Shell and BP produce the 100oct fuel. Unless caltex produces the100 then the price will stay fixed i guess.
    What name do BP market their 100RON fuel. I've never seen it at the pump.
    You can get BP 100 in a 20L drum but it is illegal to use in a road car due to the lead content.
  2. #22
    Mar 2008
    100 octane?
    Lookes like United is coming to the party.
    http://www.unitedpetroleum.com.au/index.asp?pgID=65
    If their pricing will be like for their 98 octane product, it should put the wind up Shell.
    Pity about the limited availability though
    Jun 2008
    so since Shell phase out their V Racing, where can we can 100oct fuel??? (in sydney)
  4. #24
    Sep 2007
    i think they've stopped stocking it in sydney. or at shell.. i cant seem to find it anywhere..
    i tried e10 the other day. it's not bad. and it's frikken cheap too. similar power to 95 - 98. bit more fuel consumption. but smooth and responsive.
    87' MK2 GTI
    13' MK7 TDI
  5. #25
    Mar 2007
    Quote Originally Posted by jayjay View Post
    You're running your VAG vehicle on E10? I've heard that's ... um ... a bit bad for your lump.
    Dave
  6. #26
    Nov 2008
    Killara Sydney
    Shell V power 100 octane
    Guy's, I use this in my car whenever I can get it, at one stage there was no 98 available from shell for about a 2 months in Sydney. I noticed a differance not only in my car but we were filling Bentley's with this fuel and both performed great. Milage increased slightly better than 98.
    Joe Chu
  7. #27
    Jun 2008
    ^you cant get it anymore from shell since last year... 100oct with 5% ethanol? hmmm
  8. #28
    Mar 2009
    Wagga Wagga
    Quote Originally Posted by hokenmk3 View Post
    BP Ultimate and Mobil Synergy 8000 are true high octane fuels. All other fuels marketed as high octane fuel are regular fuel with an octane booster... this octane booster only has a 2 week shelf life which has already started before the fuel has even been delivered to the petrol station. By the time you fill with it it has already been mixed for 10 days and has only 4 days of shelf life left. After shelf life has expired, it loses its octane rating and burns dirty damaging your catalytic converter.
    Cummins sell avgas
    My NA 2.0L 8v Mk3 Golf is faster than my 174kw twin turbo Supra. V8 utes and over modified Skylines hate being overtaken by old Golfs
  9. #29
    Dec 2008
    Just to add to the thread, some advantages and disadvantages of using ethanol as a fuel:
    + Burns more cleanly and efficiently than petrol
    + Ethanol has a lower ignition temperature than petrol so ignites more readily
    + Can dissolve gunk built up, cleaning the engine
    + Increases octane rating
    + No engine modifications needed for 10-24% ethanol/petrol blends
    - Produces less energy per gram than petrol (:. less power)
    - Higher flash point of ethanol means its harder to combust in colder temperatures
    - When ethanol is >25% by volume, a higher compression ratio is required to prevent greater engine wear
    Quote Originally Posted by Ben_GTI View Post
    I like tubgirl more.....but meh each to their own right?
  10. #30
    Mar 2009
    Wagga Wagga
    my cousin is a retired chemical engineer that used to work for Mobil and she said the only cars that can handle alcohol in fuel are Toyotas and Fords built since 1976. The metal used in the valves in all other cars is not suitable for use with fuel that has that much alcohol in it.
    Because it burns for longer, it is in contact with the exhaust valve stem for longer while it is still burning and will wear out non-Toyota and non-Ford valves VERY VERY quickly. This does not mean Toyota and Ford valves are better quality; it just means that the valves in all other makes of car are not suitable for fuel with higher alcohol content.
    PLEASE TAKE NOTE
