Originally Posted by
Hillbilly
Interestingly in the USA the standard grade is only 87 Octane and in one place 86. Premium is 91. Must be slightly different rating to here perhaps.
Our octane numbers are RON (research octane number) while the US use (RON + MON) / 2. MON (motor octane number) is usually about 8 - 10 points lower than RON so their 87 is about the same as 91 here and their 91 is equivalent to 95 here.
Resident grumpy old fart
