Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Polo 6r, what oil?
  1. #21
    Dec 2008
    Sydney/Canberra
    You can't go wrong. Volkswagen Australia have specified this for our market, in all vehicle across the range, built since 2007.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  2. #22
    Jan 2009
    My manual says 504 for "with longlife" 502 "without longlife" so what should it be
    You must use 502.00 at the very least. Approved 502.00 lubricants are absolutely fine to use, just not as advanced as 504.00 is all.
    You can use 504.00 even if your vehicle isn't on the LongLife regime, but it must be changed at the same fixed intervals - no later than 15 000 km/1 year.
    No matter which, the oil used is not an Approved VW oil and therefore shouldn't have been used in a 9000km car IMHO
    It should not have been used regardless of mileage if the vehicle is under warranty.
    Is it not better to use the highest spec oil ( 504/507) rather than just "One that will do" ???
    I recommend the use of 504/507 lubricants, particularly in FSI/TSI/TDI engines.
    504/507 is backwards compatible with VW's older specifications like 503/506, 502/505, etc (except for the R5 TDI and V10 TDI), but I don't specifically recommend 504/507 in older engines when 502/505 will do just fine in these applications.
  3. #23
    Pacific Paradise QLD
    Have changed oil and filter to Castrol approved 504/507 so should be OK now.
    Garage who stuffed up giving reasonable refund so I wont name them or go back there either
