Results 21 to 30 of 39
Thread: Penrite pink coolant is it really VW approved?
  1. #21
    Jun 2013
    Leichhardt, NSW
    I would def use demineralised water.. Out of curiosity (not aying this is right or wrong) thought i would investigate further the diff between red v green coolant.. I found a very interesting article I thought I would share. Def worth a read
    Antifreeze: Red or Green?
    Enjoy the read
  2. #22
    Jun 2013
    Leichhardt, NSW
    Funnily enough, needed to go and pick up some oil and whilst in the shop, had a quick look at some of the green coolants at hand out of curiosity (sorry guys, im one of those real inquisative people) to take a look at specs, etc.. and many of them claim that they are compatible with VW Motors,etc.. Myabe the newer stuff has come along way in recent years. I guess like everthing, people have choices and ultimately the choice comes down ot the the end user. Most important thing is you do youe research before deciding to go either red or green,
    By no means am I trying to state that red is better or vice versa.. it seems they both have their pros can cons.
  3. #23
    Pacific Paradise QLD
    Quote Originally Posted by Tubbs76 View Post
    Lots of products state they are "compatible " with VW but it the ones that have "Approval" that should be used.
    To get this approval they have to submit a product for testing (at a cost) and if it passes they get a letter like this which allows them to put "Approved by VW on the product container
    http://www.penriteoil.com.au/oem_pdfs/EPLUS5W30_VW.pdf If it doesnt have that I wouldnt use it in my vehicles
    http://www.penriteoil.com.au/product...d_products=272
  4. #24
    Jan 2009
    These days, it would extremely unwise to go by colour alone when deciding which coolant to use, as demonstrated below:
    G11 (VW TL-774 C)
    Mono-ethylene glycol hybrid coolant (OAT with silicates but no nitrates, amines or phosphates) dyed blue.
    G12 (VW TL-774 D)
    Mono-ethylene glycol OAT coolant (no silicates, nitrates, amines, borates or phosphates) dyed red.
    G12+ (VW TL-774 F)
    Mono-ethylene glycol OAT coolant (no silicates, nitrates, amines, borates or phosphates) dyed purple.
    G12++ (VW TL-774 G)
    Mono-ethylene glycol lobrid coolant (OAT with reduced silicates, but no nitrates, amines or phosphates) dyed purple.
    G13 (VW TL-774 J)
    Mono-ethylene glycol and glycerine lobrid coolant (OAT with reduced silicates, but no nitrates, amines or phosphates) dyed purple.
    In terms of chemical compatibility, all G12 and G13 coolants can be mixed with each other.
    However, in terms of vehicle application, G12, G12+, G12++ and G13 coolants should generally be used in a forward-compatible (rather than backward-compatible) manner. As such, Volkswagen recommends that:
    A car factory-filled (or flushed and refilled) with G12 should be topped up with G12 or G12+ or G12++ or G13.
    A car factory-filled (or flushed and refilled) with G12+ should be topped up with G12+ or G12++ or G13.
    A car factory-filled (or flushed and refilled) with G12++ should be topped up with G12++ or G13.
    A car factory-filled (or flushed and refilled) with G13 should be topped up with G12++ or G13.
    Always refer to the owner's manual on which coolant/s the vehicle should use.
    Quote Originally Posted by rutti View Post
    Does anyone know or have experience in using the Penrite pink coolant? The label says its approved for VW and also mention equivalent to g12. Repco is currently having a sale on the 5l ones.
    Penrite 4 Year Extended Drain (green) is approved for applications requiring G11 (VW TL-774 C).
    Penrite 5 Year Extended Drain (magenta) is approved for applications requiring G12 (VW TL-774 D) and G12+ (VW TL-774 F).
    If this is for your Mk2 Golf GTI, you could probably use any decent coolant that's on the shelf. I don't think a G12+ coolant is strictly necessary. Although if the price is right...
  5. #25
    Jun 2013
    Leichhardt, NSW
    cool. In about 6 weeks, im getting my timing chain done. Ill hold on till then and get them to do a flush and go to G13.
  6. #26
    Jan 2009
    Even though one would always reco factory, to my knowledge, any pink / red coolant can be substituted. I find the toyota (red) coolant is very good and ran this for a while. comes mixed at 50/50 ratio. To be honest, there really is no difference between red and green coolant apart from the cost. one does not out perform the other. I know many people who have flushed their systems and have gone over to green for the simple fact that the long term running costs are far less.
    Whoever told you all that is not strictly correct.
    If we're talking in the context of older vehicles, then you could probably get away with that - but for modern vehicles, that just doesn't cut it.
    Toyota Super Long Life Coolant
    Mono-ethylene glycol hybrid coolant (OAT with reduced phosphates, but no silicates, nitrates, amines or borates) dyed pink.
    Compare this with the VW coolants.
    Traditional coolants that use inorganic additives, such as silicates and phosphates, tend to deplete much faster and require more frequent replacement intervals.
    Newer coolants that use organic additives (organic acid technology or OAT) have significantly reduced depletion rates and require much less frequent replacement intervals.
    Hybrid coolants use a combination of organic and inorganic additives.
    Lobrid coolants use a combination of organic additives with a small amount of inorganic additives.
    All four coolant types work well when used in their intended applications and when used as specified.
    It is important to use the correct type of coolant specified for your vehicle, for reasons of material and additive compatibility, which affects corrosion resistance, deposit formation and, ultimately, component longevity (particularly aluminium and rubber swelling). There's more to coolants than just cooling.
    Unless one hasn't already realised, the colour of the coolant is mostly arbitrary.
    Always follow the manufacturer's instructions. Avoid mixing different coolant types unless stated otherwise.
    In emergencies, it's simply best to top-up with water (preferably distilled or deionised) rather than mixing different coolant types.
  7. #27
    Adelaide hills, SA
    Good explenation Diesel_vert,
    Quote Originally Posted by Diesel_vert View Post
    That's very politely said. I say who ever said that, he was wrong.
    I agree, the chlorinated tap water will react with aluminium in the engine and the radiator.
  8. #28
    Jun 2013
    Leichhardt, NSW
    Understood. Correct or not correct dependant on what context you are ref to. Either way, I'll def swap mine out for g13 when I get my chains done in about 6 weeks
  9. #29
    Oct 2010
    Melbourne, VIC
    Ditto
    Here is some further good information on VW cooling systems by ECS Tuning - the only real difference between G13 and
    G12++ is that 20% of the MEG has been replaced with glycerine for environmental improvements (toxicity and CO2 production).
    It also explains why the small amount of silicates were added to G12++ (and G13)
    Resident grumpy old fart
  10. #30
    Adelaide hills, SA
    I would stick with the G12++ which is more comon, and wouldn't mix them either, but that's only me. The flushing only needs to be done with the filtered/demineralized water, I wouldn't use the radiator flush or other chemicals unless there is oil contamination.
