I can't find a tech spec sheet for this oil on the Castrol web site ?!? but there are 2 for the GTX3. The GTX3 15W-50 meets VW501/505, but the GTX3 10W-30 does not meet any VW spec at all. It may be wrong to assume GTX 2 doesn't meet VW anything, but when they don't tell you, you have to assume that's the case.
At 20W-50 the GTX2 seems to me to be a bit high in the viscosity, unless your engine is very worn . I have used Magnatec in my Jackaroo and it burned lots of oil and rattled more when cold, but I get none of those issues with HPR10 :)
HPR10 is a bit dearer than the GTX2, you should be able to get it for $35 or less (Repco usually has an across the board sale in January, it's a good time to stock up on this sort of stuff :) )
