Results 1 to 10 of 51
Thread: Best Diesel: Shell? Caltex? BP? Mobil?
    Feb 2009
    Melbourne, VIC
    I just did some researches on different diesels (normal diesel, no bio, no premium), the result is shown below(No Mobil Diesel Data)
    PROPERTIES -[Shell]- -[Caltex]- -[BP]-
    Sulfur -[8]- -[<=10]- -[<=10]-
    Flash Point -[79]- -[>=61]- -[No Data]-
    Density -[0.82 – 0.85]- -[0.82-0.86]- -[0.82-0.85]-
    Cetane -[49]- -[>=46]- -[51, >=46]-
    Lubricity -[400]- -[<=460]- [<=460]-
    Which one is best for performance and economy?
    Lapiz Blue GOLF R MY16
    Adelaide hills, SA
    I use BP and Shell as second choice. The long term fuel economy in my T5 is - 9.5L/100km (very short trips and fully loaded). Done 65k now.
    Feb 2009
    Melbourne, VIC
    New research result:
    higher sulfur = more smoke(bad for environment) = higher Lubricity(good for engine)
    higher cetane = more power
    Thus it seems BP is the best.
    Feb 2008
    Richmond, VIC
    Any idea what Mobil is, thats what i generally use as its closest to home.
    currrently... MY10 GTI | DSG | Candy White | Sunroof | 18's | BT | MDI
    previously... MY08 GT TDI | DSG | Reflex Silver | Sunroof
    Adelaide hills, SA
    Quote Originally Posted by steve_tdi View Post
    Last time I asked Mobil (1 year gao) it was CN 46.
    Jul 2005
    Newcastle, NSW
    I use BP, get worse economy out of Caltex.
    Feb 2008
    Townsville QLD
    Shell FTW
    Shell is best for economy for me as I get $0.08 per litre off at Coles express so works out best in terms of cents per km. $0.04 shopadocket plus $0.04 voucher that comes with statement when I pay with Coles mastercard.
    2 Coles outlets in Townsville go very close to matching the best el cheapo independant price while the other 2 are $0.10 dearer so they miss out on my business.
    With Cetain so close to BP I cannot tell the difference so performance is not an issue for me.
    Granite Passat sedan TDI (125kw), DSG, beige leather
    Candy White Polo 6R, 66TDI, DSG, no options
    Jun 2009
    Northfield, Adelaide
    This is the specs on the BP Ultimate diesel
    BP Ultimate Diesel is a refined premium diesel fuel with higher cetane and lower sulphur than specified in the Australian Standard. It is formulated to burn better than ordinary diesel fuel and remove deposits from vital engine components such as injectors, enabling engines to run more smoothly and efficiently. BP Ultimate Diesel is formulated to help protect the engine against the harmful effects of corrosion and wear. BP Ultimate Diesel’s foaming characteristics have been modified to reduce the likelihood of spills and splash back. Compared with ordinary diesel, using BP Ultimate Diesel will provide;
    Protection against rust and wear Reduced foaming, leading to quicker, cleaner and safer refuelling Minimal rough idiling
    BP Ultimate Diesel is designed for use in normally aspirated and turbocharged high speed diesel engines.
    PROPERTIES
    BP Ultimate Diesel exceeds the requirements of AS 3570, the Australian Standard for Automotive Diesel Fuel, and the requirements of the National Fuel Quality Standards 2000 diesel determination of 2001. BP Ultimate Diesel is comparable to EURO 5 diesel fuel.
    Cetane rating 50 min typically 55 to 60
    Sulphur 10 mg/kg max
    Jan 2009
    Exclamation BP Ultimate Diesel Supply
    Release date: 02 December 2009
    BP Australia advised its customers today that ongoing issues at its supply terminals have delayed the company’s ability to restock a number of its service stations in the Perth, Adelaide and Brisbane areas with BP Ultimate diesel.
    Supplies of regular diesel are not affected.
    BP is putting a number of measures in place to ease the supply situation. One immediate action is to replace BP Ultimate diesel with regular diesel at all affected sites.
    Accompanying this change will be point of sale information to ensure customers are made aware that only regular diesel is being supplied.
    BP regrets any inconvenience caused and will update customers as and when BP Ultimate diesel sales recommence.
    Doesn't affect Sydney - only because it's not available here
    Jan 2009
    Perhaps this might have something to do with it - BP Says Australian Oil Refinery Unaffected as Workers Strike
