Results 1 to 2 of 2
Thread: Oil viscosity calculator & other oil tools
    Adelaide hills, SA
    Just thought some of you might be interested.
    Graph your oils
    The Lubrizol Corporation
    Temperature range of different engine oils and oils generally. Important fact to consider when you're going to downgrade your engine oil from VW recommended latest specs oil to something like VW 502.00 or lower. Think about your turbocharger and how hot the oil gets, turn ON your MFD to display the engine oil temperature and re-think.
    Shelf life of synthetic oils http://www.amsoil.com/techservicesbu...20Handling.pdf
    Gosford Central Coast NSW
    Thanks!
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
