Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: oil time
    Oct 2006
    sydney
    oil time
    i just bought some lube motul competition 15w50sae do you guys think it would be ok for my vr6??? i usally use 20w50 in mobil
    motul also have a 20w60 but i thought about it but would be too thick
    its pricey all up $90 but really good oil
    Aug 2007
    Perth, Australia
    its thinner than the one you are using so it can't be worse. You might need to change it earlier, and it burns easier
    1991 BMW 318is RED E30
    Oct 2006
    sydney
    Quote Originally Posted by balkanac View Post
    i got the motul bc my mates audi rs6 has that in it and ive checked it since i serviced it and the oil colour is still good i does burn alittle but is standard being german i may buy a 2L bottle for that alone
    Dec 2006
    Kilsyth, VIC
    Everyone will have a different opinion on oil and there have been many many threads where people have asked is XXX brand good for my car or not.
    In short, stick with a fully synthetic oil of a grade that doesn't burn off in two weeks. Personally I use Fuchs 10W40:
    The VR6 tends to drink a little oil so you need to keep on top of it, I check the oil whenever I add fuel and add as needed.
    Oct 2006
    sydney
    ive heard good things about this oil too but im sceptical as our cars are not new cars and this oil 10w40 is standard for all petrol engines at vw dealerships and what is in the owners manual but for a vr6 i thinks its too thin
    Jan 2008
    Quote Originally Posted by william View Post
    The oil helps clean up the internals of your engine. If it maintains its 'new' colour then the oil is not cleaning your engine internally. I know it dosent sound right but the quicker it turns black the better the oil in keeping deposits from building up on internal parts.
    Mar 2006
    Canberra
    Smile
    I use the Fuchs synthetic fortified Performance Plus 15w/40 for the Little Beasties SEAT 1.8. It is time to change the oil and it is still opaque! It also only $29.95.
    Old Skool Passat Power Rules!!!
    1974 Passat LS with a SEAT 1.8, 32/36 Weber, full performance exhaust and a K&N filter. 80kw at the wheels??
    Feb 2008
    New Zealand
    I always you Castrol Edge 10w60
    the GTI loved it..
    120,000kms and no signs of giving up and i gave it death every waking hour of the day..
    it doesnt sludge either and block the oil feeds!
    - 2010 Golf R
    - 1997 Golf VR6
    - 1989 MKII Golf Diesel
    - 1987 VW Golf GTI 16V
    Dec 2006
    Kilsyth, VIC
    I wonder about that myself as the VR6 burns off a bit of oil... close to 100ml a week and I don't have any leaks so it really is burning off. Mind you I check the oil whenever I fill up and have a measuring cup in the garage, so when I get home I stick a little extra in.
    It's a real debate in my mind, the VR6 is a hot engine and WILL burn oil. As long as you are aware of it and check it every couple of weeks it's not an issue. The 10W40 seems to perform very well otherwise so again I'm not really looking at something else.
    I would be very interested to hear from other VR6 owners how much oil they burn off and what grade they are running.
    Oct 2006
    sydney
    i burn about 500ml every 3months or so i check mine regularly, it usual burns off in through the exhaust system it is normal as european cars where not made for australian climate its hotter than in europe running temp is higher oil burns quicker my opinion some may have others
