Any comments on oil sludge removal?
I've read a few threads on PassatWorld about oil sludge removal.
A quick look around and I've found:
Nulon : http://www.nulon.com.au/products.php...gine_Oil_Flush
CEM : http://www.costeffective.com.au/prod03.htm
OWS : http://www.ows.com.au/products_vitamins.html#210
Any thoughts/comments?
I have a '99 Astra with rattling lifters to experiement on before putting it in my B5 wagon! Just wondering if there's any experience with particular products on this site?
Ok... Any engine flush will do, just add the flush to oil & drive around the block until thermo fans cut in. Have everything set up before hand so you can change the oil & filter when hot. (Be very careful HOT!) I would use a semi syn oil. Change the oil & filter every 3 months the same way until the sludge has gone.
Rgds, Jaimo.
06 Jetta/09 Pirelli/DSG
08 T5 BPC/Auto
08 Caddy Maxi life TDI/DSG
12 Up!.
