Results 1 to 10 of 19
Thread: Oil Change Question
    Oct 2010
    Oil Change Question
    Thinking about going to stg 1 and beyond in my mk5 GTI. But I'm trying to decide what to do in terms of regular oil changing.
    Up to this date I have got the car serviced to manufacturer specifications i.e. every 15,000km and minor/major as per logbook. Before everyone jumps on and says change it every 10,000km or less, here is my question:
    My car is a fairly heavy oil user (about 1L per 1500km on rough calculations), which I suspect might be due to the way it was driven by the first user?!! So I'm topping up the oil every 3000km or so with fresh oil.
    Now, if I'm adding new oil at this frequency does this lower the need to change the oil out of the car completely before the 15,000 VW recommendation? Or is that oil just added to the old oil in the sump and therefore become "dirty" as well? Looking for considered responses, rather than people's preferences if possible, because I know everyone has a slightly different personal opinion about changing their oil
    MY07 GOLF GTI
    5-Door l Tornado Red l DSG l Leather l Xenons l MFD2 l TCP T.B.E l DNA stage 1
    Apr 2011
    Damn that's a lot of oil, must have a pretty ****ty seal between the cylinder wall and rings (either that or your valve stem seals are shot). Personally I wouldn't bother modifying a car with an engine like that, but if you are going to despite its condition, there's 2 options IMO - just top it up as you need to and change it properly every 10-15K kms, or treat it like it's in good condition and change it more regularly (ie: 5-7.5K kms). Regular full changes would be better, but whether or not its worth it is your call.
    Oct 2010
    According to the manual and the dealer - when I questioned it last service - this engine (2.0TFSI) can use up to 1L/1000km. They did a quick scan but found nothing wrong. The car has been serviced by dealer like clockwork since new so I think calling the engine in poor condition might be a bit strong.
    Spent a bit more time last night doing the calcs and I reckon it's closer to 1L/1750km. It's improved the longer I've had the car
    Any other opinions on OP question?
    MY07 GOLF GTI
    Apr 2011
    I wasn't having a go or anything and didn't mean it to sound like a strong statement, but Audi/VW engines have a bad reputation for excessive oil use, and 1L in ~2000km is pretty bad compared to say most Japanese engines. My Evo uses no oil (visible on dipstick anyway) in 5000km, even driven spiritedly. My mates GTR34 uses none either. No top ups in a full oil change interval with oil still at full line. I'm yet to see if my VR6 uses any, its still in the run in period.
    The rings in your engine either don't seal properly (in which case you may be losing power too), the valve stem seals are leaking, or your turbo seals are leaking, have you checked the intake pipe for oil residue? Dealers tend to say "its fine" up to the point of failure depending on how dogy they are, but since those engines are known to use oil due to poor ring seal, I guess it might me 'normal'. Audi/VW I believe say up to 1L/1000 miles is ok,but to me that's ridiculous and indicative of a poor ring seal or other issue.
    Dec 2006
    Kilsyth, VIC
    The handbook for the VR6 says up to 1L/100KM is normal so it's not just the dealers.
    Adelaide hills, SA
    At the end of 70's and right till 90's, the engine that used more than 0.7L/100km was considered as worn out and in need of rebuild.
    When the engine oils with the viscosities 5W30 and lower came to the market, many engines started to use more oil than normal and the car manufacturers simply announced that the oil consumption of 1-1.5L per 1000km was normal.
    When checking for excessive oil consumption, remember to check the intake system and the intercooler for heavy oil deposit in them, caused by leaking/worn out turbocharger. It happens to the new cars with as low as 40,000km.
    Apr 2011
    Yes, but there are many engines that run high boost with 5W-30 or thereabouts and use none ie: 4G63, RB26DETT. As I said before Audi/VW engines have a reputation as oil burners. If you know why they are burning oil its up to you to say if its ok or normal, personally a late model engine with poor ring seal or leaky valve stem seals is not acceptable, and I would get rid of the vehicle, not modify it and by doing so increase its oil consumption (raise boost etc). I had an old nissan as my second vehicle which at the end of its 21 year life used 1L/1000km and when I pulled the engine down the valves were encrusted with soot from the oil combustion and the headers were full of it. The engine was gone, no-one said 1L/1000km was ok, not a mechanic, nor anyone with any vehicle experience. If its the rings on the Audi's that wont seat the run in procedure needs to be looked at - either too gentle or too hard. Beyond that the metals used for rings and cylinders may be the issue or QC in the factory, but they're hardly likely to admit fault with the design at this stage. Some guys have issues and some don't, but I've not read anything conclusive as to exactly why it happens.
    I asked the OP in my previous post if he'd checked the intake for oil indicating turbo seal failure, but he has not replied.
    Adelaide hills, SA
    Hm, Japanese cars usually don't specify only 5W30 but allow much heavier grades to be used, so it could also mean that they use heavier oil right from the first oil change. Keep in mind that 5W30 oil is usually at least semi-synthetic (more expensive) and many workshop would use the cheapest oil they can get away with and still be within manufacturers specs.
    I have 4 VW in family and none of them use oil. All serviced by me (every 7,500km or more often), never been to the dealer for the oil change. I agree 15,000km or 12 months is way too long between oil changes. IMO, oil should be drained as soon as the car comes of the boat, who knows how long the engine spent idling and how many short trips the car had when it left the factory.
    Apr 2011
    I wouldn't say 'much heavier' grades can be used in japanese cars, my Evo needs 10W-30 for our temp conditions according to the manual, but SAE 40 is ok too, no thicker according to the manual. Mobil1 0W-40 is factory fill for GTR's. That oil often shears to a heavy SAE30 pretty quickly. Thin oils are usually specified these days for 'eco friendliness' not engine life extension (same reason they're reducing the amount of additives and detergents in oils), SAE 30 is as thin as I'd go in Australia. The japanese build engines tighter than anyone and they are around the SAE30 mark. Something like German Castrol would be ideal but I doubt the aussie dealers use it. I'd be pissed if VW used anything less than full synthetic in my car though, it has to meet 504 spec so there are a few decent choices available, but if they dont I'll find somewhere that does and use them for my factory servicing instead. I'd do it myself but I'd then not have the service logbook which most people insist on when buying second hand.
    Plenty of people have oil burning issues with certain audi/VW engines. Not so much with any other brand from what I've noticed. They even mention it in audi/vw car reviews sometimes as a 'trait' of the vehicles. It's just poor form these days IMO, rings should seal, end of story. If someone's ok with them not sealing that's up to them, I think its unacceptable.
    Oct 2010
    In reply to the question, I had the whole intake off a couple of months ago and no oil residue present unfortunately. Don't get me wrong, I'd be more happy if the car didn't use oil like it does, but it has been flawless since new for both the first owner and now me so I don't have any major concerns.
    I don't have enough knowledge or desire to get into the whole oil use in different types of engines debate (although I did have an SR20 before buying the Golf so I'm not foreign to Jap engines).
    Just looking for an answer to the original question.
    Quote Originally Posted by TomC View Post
    MY07 GOLF GTI
