Results 1 to 6 of 6
Thread: Which oil?
    Mar 2006
    Canberra
    Unhappy Which oil?
    I am about to do my first oil change on the Little Beastie. I have a short list, please comment as this would be a great help. When Matt put the SEAT 1.8 in he said it had around 120k, and he uses Castrol, and the CVWC uses Fuchs, or so confusing. I have had good results previously with Valvoline Max Life and then HPR 40 with the old wheezer engine.
    Valvoline - Engine Armour
    Fuchs - Titan GT Plus
    Titan Super GTO
    Castrol - Magnatec 10w 40
    GTX3 15w40
    Nulon - 15w40 Modern Engine Oil
    Penrite - HPR 10
    Most of these I think a blends.
    Old Skool Passat Power Rules!!!
    1974 Passat LS with a SEAT 1.8, 32/36 Weber, full performance exhaust and a K&N filter. 80kw at the wheels??
    Jul 2005
    Newcastle, NSW
    The only advice I have is that you may be on the thin side with the grade, I would be putting in a 20 or 25W instead of a 10 or 15 as if it is not consuming oil now, going to a thin grade may not help in that stake.
    I am not sure if you know what weight is in it now... but I would not go any thinner.
    I may be too cautious!
    If your engine is only around 120k old I wouldn't be going too thicker grade either.
    With engine out of my old beater, which is now in the gti & nearly 400k old, I run Mobil Super XHP 15w-40 from rebuild (a very long time ago) & have never had any problem's at all. No oil consumption ever.
    I also run this in my mum's Mk2.
    The oil's you have used in the past like HPR40 are for older engine's which are on the worn out side of thing's & are for mainly curing engine knock, blowing smoke etc. I wouldn't be running that in a fresher engine.
    Mar 2006
    Canberra
    Unhappy
    After reviewing this thread and doing some more research I am still confused. It sometimes smokes on start up and I have a few leaks from the pan and the bolt( will replace sumpwasher. Can anyone please help me?????????????????
    Blackburn South, Victoria
    looking up the haynes manual, it recommends 5-40 to 20-50 for the petrol engines. my 2.0l has 138000kms and i changed it over from 15-40 to 5-40 (fully synthetic) and am having no issues...
    2018 MY18 Indium Grey VW Golf 110TSI Comfortline, DAP & Infotainment, Folding Mirrors!
    2023 MY23 Nevada White Cupra Formentor VZx
    2015 Carnival Yellow Honda S660
    Mount Colah NSW
    If you go to the VW "Erwin" site you can register and login free of charge and there you will find a free download of all VW approved oils. Most synthetics brands are listed.
    https://erwin.volkswagen.de/erwin/showHome.do
    ZZZZZedder
    2007 Jetta 2.0FSI
