Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: MKV R32 Engine Oil & Fuel Additives
    Mar 2008
    Did my first oil change in the R32 over the weekend with Penrite Enivro+...
    Even at 7,500 kms, the oil was dark and well, yuck. Wouldn't have wanted that in there for another 7,500kms.
    I know that the oil may have been ok even though it didn't look it...but I always feel 'cleansed' after an oil change...very therapeutic.
    Oct 2010
    Tapping, WA
    Good work. I picked up a few packs of Shell Helix Ultra Extra 5w-30 at the Repco 20% sale a month or so ago. Her first service under my ownership is due in a couple of months and will be about 7,500kms. Very interested to see what the used oil comes out like.
    Daily - MY09 MKV R32 - Deep Pearl Blue
    Family - MY09 Subaru Forester XT - Satin White
    Mar 2008
    If you're going to do it yourself, make sure you have a 36mm socket amongst other tools.
    Still getting use to euro cars from jap cars...apart from the indicators being on the other side:
    1) wheel bolts reversed
    2) filter elements instead of filter cans
    Aug 2007
    Perth, Australia
    I changed the oil and filter in mine fe weeks ago. I used Castrol 5w30 and the car is running much smoother. The oil was black that came out, eventho it did 6K km since the last oil change (it was a year ago tho)
    changing the filter was the biggest pain in the a$$, there is a plastic cover that goes from the bumper to just after the filter. I cut my hands so much to get it out!! Hope its different on MK5s
    1991 BMW 318is RED E30
    Mar 2008
    Quote Originally Posted by balkanac View Post
    Yep, still a plastic cover...but after taking out 8 or 10 bolts, the cover slides off pretty easily.
    The most this baby is going to see from now onwards is 7,500 kms between drinks.
    Apr 2011
    I'd never recommend running an engine for 15000kms on the same oil. Some engines are easier on oils than others (operating temps, shearing etc) and Audi/VW engines do not have a good reputation, rather they sludge up very easily and are very hard on oils. Long life or not, 5000-7500kms would be as far as I'd go. Have a look over on the BITOG forums and check out some UOA's and see the wear metals increase when pushed past 5-7.5K kms, not worth the extra wear and tear IMO, I'd rather just change the oil.
    Fuel additives I have on good authority (fuel injection specialist who was a good mate of my tuner and whom I spent a fair bit of time with) are a bit of a wank. Some will work a little, but good quality 98RON has additives that should keep things pretty clean, and that after about 40-50K kms, you should pull the injectors and have the ultrasonically cleaned (~$22 per injector). No additive comes close to a proper ultrasonic clean. Just use 98, and get them properly cleaned every 50K kms or so, much cheaper than buying fuel additive all the time.
