Results 1 to 10 of 16
Thread: MKV R32 Engine Oil & Fuel Additives
    Mar 2008
    Morning all!
    Just received my R32 last night which has done 34000 kms. A couple of quick questions as i like to look after my babies
    1) I know its VW 504 oil i should be using but the manual doesn't state viscosity rating. What oil do you guys recommend?
    2) is r32 a long service vehicle that requires oil changes every 15000 kms? If so, should i be changing the oil every 7500 kms as i usually change my other car every 5000 kms.
    3) i read about fuel additives from vw i should be using. What interval do i use it? And would the 30000 km service have added it?
    Cheers, michael.
    Adelaide hills, SA
    VW504 oil is 5W30 if it says different viscosity, then it most likely isn't VW504 approved oil. I use in petrol engines Interject injector cleaner (415Y) every 3rd fill up.
    It depends where you drive and how but 7,500km max. is what I do on oil in engine.
    Even the Supercheap Auto is selling Shell Helix UltraExtra for less than $75/5L now, so it is not that expensive to change the oil, especially if you can DIY.
    Mar 2008
    Thanks Transporter! I was a little concerned when I read that oil in the long service category can last for 15,000kms...I'll take the halfway route.
    Mar 2008
    getting two bottles of penrite enviro tomorrow.
    Jan 2010
    North Shore
    Not really sure why you wouldn't change at the manufacturer's recommended interval. Oil quality has improved significantly since the days of having to get your oil changed every 5000km. Changing it sooner is really just a placebo.
    Mar 2008
    Quote Originally Posted by Rob Burns View Post
    Ah, call it paranoia...when I change oil even at 5000kms in my Suby...it's quite dark... Good feeling for around $80...
    Adelaide hills, SA
    Some people like to care for their cars bit better than others.
    Hmm, manufacturer recommendation... let me think about it... it is indeed only a recomendation to me. Now, I can already hear you thinking; "Another one who thinks that he is smarter than the VW engineers".
    Let me remind you something VW Audi Oil Sludge Class Action Settlement and to that,I can only say that, I rather change oil more often than be one of these 480,000 affected.
    Jan 2009
    Quote Originally Posted by noisuf View Post
    The only viscosity range 504/507 oils are made in is 5W-30.
    Good to see you've already bought two bottles of Penrite, but for future reference here is a list of known oils available in Oz. Any of them will do really, they are after all made to the same specification.
    2) Is R32 a long service vehicle that requires oil changes every 15000 kms? If so, should i be changing the oil every 7500 kms as i usually change my other car every 5000 kms.
    "Longlife" in VW speak refers to "variable service intervals" which range from 15,000 km/1 year to 30,000 km/2 years as determined by the onboard computer, and requires the use of "Longlife oils" i.e. 504/507 oils.
    Australian delivered vehicles are on "fixed service intervals" (15,000 km/1 year) so "Longlife oils" aren't required, but that doesn't mean you can't use and take advantage of them.
    I'd change the oil between 7,500 km/6 months and 15,000 km/1 year, depending on the type of driving you do. I don't think you'd see much benefit of changing it any sooner, and colour is not really an indicator of an oil's condition.
    Alternatively, you can change the oil at 15,000 km/1 year, but replace the oil filter and top-up the oil every 7,500 km/6 months, which is a simple way of extending the life of the oil.
    Jan 2009
    So I clicked on the link, and then another link, and this is what I got...
    "If you owned or leased one of the following vehicles, your rights may be affected:
    Model year 1998-2004 Volkswagen Passat vehicles equipped with 1.8 liter turbo engines:
    Model year 1997-2003 Audi A4 and A4 Cabriolet vehicles with 1.8 Liter turbo engines;
    Model year 2004 Audi A4 and A4 Cabriolet vehicles equipped with 1.8 Liter turbo engines;
    for which motor oil meeting VW specification 502 00 was not required as part of scheduled maintenance (2004 A4 vehicles with VIN Numbers below WAULC68E44A152304 and 2004 Cabriolet vehicles with VIN numbers below WAUAC48H04K014467) imported or distributed for sale or lease in the United States by Volkswagen of America, Inc. d/b/a Audi of America."
    So essentially, the American arm of Volkswagen and Audi told owners that VW 502 oil wasn't necessary (ignored orders from German HQ???) and then ended up with lots of angry owners with kaput engines?
    Who made that stroke of genius?
    Adelaide hills, SA
    Yes, somebody was smarter and thought that it would be OK.
    SA dealer no longer sells Castrol oil, they have fully imported oil from EU. I wander what triggered the change? ... but I think I already know the answer.
